      怎么樣的陶瓷餐具才是好餐具?
      怎么樣的陶瓷餐具才是好餐具?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2019-06-06 17:17:04
      餐具關(guān)系我們一日三餐的性,那么什么樣的餐具才是好得、健康的餐具呢?下面鑫科一次性餐具廠家就給大家總結(jié)一下購(gòu)買餐具的一些注意事項(xiàng),希望對(duì)大家有所幫助!
      Tableware is related to the safety of three meals a day. What kind of tableware is good and healthy? The following Xinke disposable tableware manufacturers will summarize some points for attention in the purchase of tableware, hoping to help you!
      一,如果你有自己的審美趣味,買你覺(jué)得漂亮的。
      First, if you have your own aesthetic taste, buy what you think is beautiful.
      二,如果沒(méi)有,買貴的。
      Second, if not, buy expensive.
      有的朋友把‘’好餐具‘’理解為“的餐具”,其實(shí)大可不必。現(xiàn)在的餐具絕大部分是的。
      Some friends understand "good cutlery" as "safe and non-toxic cutlery", in fact, it is not necessary. Most of today's tableware is safe.
      有人強(qiáng)調(diào)不能用釉上彩,其實(shí)現(xiàn)在餐具用的釉上彩染料早就沒(méi)毒性了。傳統(tǒng)琺瑯彩和粉彩有鉛砷析出,所以早就不做餐具了。
      Some people emphasize that it is not possible to use glazed dyes. In fact, the glazed dyes used for tableware have not been toxic for a long time. Traditional enamel and pastel colors have lead and arsenic precipitation, so they have not been used as tableware for a long time.
      只要通過(guò)正規(guī)渠道買正規(guī)餐具,沒(méi)必要擔(dān)心問(wèn)題。當(dāng)然地?cái)偵鲜畨K錢六個(gè)的碗,就不好說(shuō)了。同時(shí)我們也可以通過(guò)下面的小竅門來(lái)判斷:
      There is no need to worry about safety as long as formal tableware is purchased through formal channels. Of course, it's hard to put ten yuan and six bowls on the table. At the same time, we can judge by the following tips:
      一、用手觸摸,不光滑的不要購(gòu)買 挑選餐具時(shí),一定要用手觸摸,如果餐具上面的花體是凸出來(lái)的,說(shuō)明是釉上彩。觸摸時(shí)餐具表面不光滑、粗糙,說(shuō)明產(chǎn)品“沒(méi)有燒熟”,盡量不要購(gòu)買。另外,不要購(gòu)買內(nèi)壁有花的餐具,雖然產(chǎn)品質(zhì)量合格無(wú)害,但還是萬(wàn)無(wú)一失的好。
      1. Touch with your hands. Do not buy and choose dishes that are not smooth. Touch with your hands. If the flower body on the dishes is protruding, it means that it is glazed. When touching, the tableware surface is not smooth and rough, indicating that the product is "not cooked", try not to buy. In addition, do not buy the tableware with flowers on the inner wall. Although the quality of the product is qualified and harmless, it is still good without fail.
      二、用眼觀看,有氣孔的不要購(gòu)買 購(gòu)買餐具時(shí),除了要注意和質(zhì)量問(wèn)題外,餐具的使用性也不能被忽視。生活常識(shí)的小編提示,購(gòu)買餐具時(shí),好將餐具對(duì)著光看一下,如果上面有瑕疵,便可一目了然。如果發(fā)現(xiàn)餐具上有細(xì)小的氣孔、凸起、落渣、底部不平整時(shí),好不要購(gòu)買。因?yàn)?,這些有瑕疵的餐具會(huì)給日后的清潔帶來(lái)麻煩。
      2. Look with your eyes. When purchasing tableware with stomata, you should pay attention to safety and quality problems. Besides, the usability of tableware can not be ignored. The small edition of common sense hints that when buying tableware, it is best to look at the tableware, if there are flaws on it, you can see at a glance. If you find that there are small air holes, bulges, slag, uneven bottom, it is best not to buy. Because these flawed tableware will cause trouble for future cleaning.
      三、倒扣餐具,不平整的不要購(gòu)買 購(gòu)買杯子、碗、盤子等餐具時(shí),好把產(chǎn)品倒扣在桌面上或玻璃面上,檢驗(yàn)產(chǎn)品的平整度是否達(dá)到標(biāo)準(zhǔn)。如果發(fā)現(xiàn)餐具口有翹起、不平的現(xiàn)象就不要購(gòu)買了。另外,也可以把餐具摞在一起,如果好的的餐具是沒(méi)有縫隙的。而質(zhì)量低劣的餐具摞起來(lái)歪歪斜斜的。
      3. Inverted tableware. When buying dishware such as cups, bowls and plates with irregularities, it is better to put the product upside down on the table or glass surface to check whether the product's smoothness meets the standard. Don't buy Tableware if you find that it has a warped and uneven mouth. In addition, the tableware can also be stacked together, if good quality tableware is seamless. Poor quality tableware is crooked.
      四、用手敲擊,不清脆的不買 購(gòu)買餐具時(shí),用手敲擊一下,如果餐具發(fā)出的聲音清脆悅耳,說(shuō)明餐具的質(zhì)量是的。如果餐具用手敲擊后發(fā)出混濁的聲音,說(shuō)明餐具的坯體有裂縫,不要購(gòu)買。
      4. Knock with your hands. When you don't buy tableware, knock with your hands. If the sound of the tableware is clear and pleasant, it shows that the quality of the tableware is of high quality. If the tableware makes a muddy sound after being knocked by hand, it indicates that there are cracks in the body of the tableware, do not buy it.
      以上就是一次性餐具廠家的小編給大家整理的精彩內(nèi)容了,如果大家有其他要補(bǔ)充的內(nèi)容,歡迎收藏我們的官網(wǎng):http://m.hydronic.cn!給我們留言評(píng)論!我們的客服人員將會(huì)與您盡快取得聯(lián)系!
      Above is the wonderful content of disposable tableware manufacturer's small edition. If you have other contents to add, you are welcome to collect our official website: http://m.hydronic.cn! Leave us a comment! Our customer service staff will contact you as soon as possible!
