中餐餐具使用方法和注意事項(xiàng)!
是一個(gè)禮儀之邦,在餐桌上的禮儀可以說(shuō)也是非常的講究,在餐具上面也有很多的規(guī)矩。中餐的餐具大家天天都在用,但是要正確使用、有禮貌地使用,有些人就做不到了,下面一次性餐具廠家就給大家分別介紹一下餐桌上的餐具的使用方法和注意事項(xiàng),希望對(duì)大家有所幫助!
China is a country of etiquette. The etiquette on the table can be said to be very exquisite. There are also many rules on the tableware. Chinese tableware is used everyday, but to use it correctly and politely, some people can not do it. The following disposable tableware manufacturers will introduce to you the use of Chinese tableware and points for attention, hoping to be helpful to you all!
1.筷子是中餐餐具中使用非常多的,而且是直接用手接觸的餐具。放筷子時(shí),必須是成對(duì)的,拿筷子吃菜時(shí),筷子不要碰到旁邊的人,和別人說(shuō)話時(shí),要放下筷子,表示禮貌,筷子不要舔來(lái)舔去,也不要直立地插在碗中,更不能用筷子敲桌子或碗。
1. Chopsticks are widely used in Chinese tableware, and they are directly hand-touched tableware. When you put chopsticks in pairs, when you eat with them, you should not touch the people around you. When you talk to others, you should put down your chopsticks to show courtesy. You should not lick them up or put them in a bowl upright. You should not knock on the table or bowl with your chopsticks.
2.盤子和碟子有多種型號(hào),盤子一般比較大,是餐桌上盛放菜肴的餐具,除非餐具中間有玻璃轉(zhuǎn)盤,否則盤子放在桌上不要挪來(lái)挪去,那樣不禮貌,型號(hào)較小的是放在自己跟前的小碟,用來(lái)盛放從公用盤中夾過(guò)來(lái)自己吃的菜,小碟中的菜,吃多少取多少,不要浪費(fèi),雞骨頭魚刺之類的殘?jiān)旁谛〉那胺剑灰S意吐在桌上。
2. There are many types of plates and dishes. The plates are usually larger. They are tableware for dishes on the table. Unless there is a glass turntable in the middle of the tableware, the dishes should not be moved around on the table. That's not polite. The smaller type is the small dish placed in front of you, which is used to hold the dishes you eat from the public dish. How much food you eat in the small dish should not be wasted. Chicken bones, fish bones and other debris should be placed in front of the saucer, do not spit on the table at will.
3.飯碗是用來(lái)盛飯供自己吃的餐具,也有大小號(hào)之分,一般飯量大的用大號(hào)碗,飯量小的用小號(hào)碗,做客時(shí),盡量不要回碗,吃飯時(shí),可以用手端著碗吃,不要用嘴趴在桌上夠著碗吃,那樣吃相很難看,也不禮貌。
3. The rice bowl is a kind of cutlery used to hold rice for oneself, and there are also sizes. Generally, large bowls are used for large meals, small bowls are used for small meals. When you are a guest, you should try not to return to the bowl. When you eat, you can carry the bowl with your hands, and don't use your mouth to reach the bowl on the table. It's ugly and impolite to eat like that.
4.喝湯時(shí),可以用勺子舀到自己跟前的小碟或小碗中,進(jìn)過(guò)嘴的勺子不要再放回公用湯碗中舀湯,自己的唾液弄臟公用的湯,很讓人討厭。取菜時(shí),在筷子不方便夾菜時(shí),可以用勺幫著取菜,取菜后,放在自己的小碟中。勺也不要直插在飯碗中或敲擊碗碟。
4. When drinking soup, you can use a spoon to scoop up the small dish or bowl in front of you. Don't put the spoon in your mouth back into the common soup bowl to scoop up the soup. It's annoying that your saliva stains the common soup. When picking up dishes, when chopsticks are not convenient for picking up dishes, you can help pick up dishes with a spoon. After picking up the dishes, you can put them in your own saucer. The spoon should not be inserted directly into the bowl or knocked on the dish.
5.湯碗是用來(lái)盛放公用湯羹的,比飯碗要大許多,并且在湯碗中有公用的大勺,用來(lái)盛湯,湯碗一般放在餐桌中間,不可挪到邊上供自己取湯用,這是不禮貌的。喝不了的湯,也不要倒回湯碗中,那樣讓人厭。
5. The soup bowl is used to hold public soup, much larger than the rice bowl, and there is a public spoon in the soup bowl, which is used to hold soup. The soup bowl is usually placed in the middle of the table, and can not be moved to the side for their own soup, which is impolite. Don't pour the soup back into the soup bowl if you can't drink it. It's boring.
6.水杯是每人一個(gè),放在自己跟前,用來(lái)盛放飲料或茶水用的,不可以往水杯里倒食物,也不能往里面吐殘?jiān)?,那樣都是不禮貌的。也不要用水杯來(lái)盛酒,不用時(shí),也不要扣在桌上,應(yīng)保持原位。
6. The water cup is for everyone. It's not polite to put it in front of you to hold drinks or tea. You can't pour food into the water cup or spit residues into it in the past. Also do not use water cups to fill wine, when not in use, do not buckle on the table, should remain in place.
以上的精彩內(nèi)容由一次性餐具廠家友情提供,更多的精彩內(nèi)容請(qǐng)繼續(xù)關(guān)注我們:http://m.hydronic.cn,我們會(huì)有更多的精彩內(nèi)容等你查看!
The above wonderful content is provided by the friendship of disposable tableware manufacturers. More wonderful content please continue to pay attention to us: http://m.hydronic.cn, we will have more wonderful content waiting for you to see!
- 上一個(gè): 餐具清洗的錯(cuò)誤做法,你記住了嗎?
- 下一個(gè): 怎么樣的陶瓷餐具才是好餐具?
