減少一次性餐具使用率,環(huán)保餐具更有用!
市面上餐具五花八門,必須針對不同用途挑選合適的材質(zhì)才能兼顧環(huán)保與健康,玻璃可以用于微波、蒸烤,并可盛裝酸性食物,但是不耐撞擊,建議使用海綿清洗;
There are various types of tableware on the market, and suitable materials must be selected for different purposes to balance environmental protection and health. Glass can be used for microwaves, steaming and baking, and can hold acidic food, but it is not resistant to impact. It is recommended to use a sponge for cleaning;
聚丙烯塑膠耐酸堿、耐油脂、酒精,容易老化需定期更換,清洗時(shí)宜使用中性清潔劑;
Polypropylene plastic is resistant to acid, alkali, oil, and alcohol, and is prone to aging. Regular replacement is necessary, and neutral cleaning agents should be used for cleaning;
不銹鋼耐熱,使用壽命較長,但不可微波,要避免使用鋼刷或菜瓜布等剛性刷材清洗。
Stainless steel is heat-resistant and has a long service life, but it cannot be cleaned by microwaves. Avoid using rigid brush materials such as steel brushes or vegetable cloth for cleaning.
近年很流行矽膠的餐盒或是吸管,矽膠材質(zhì)輕巧、具有彈性同時(shí)可微波,但須注意部分的矽膠可能不耐熱,并且容易受靜電力而沾附灰塵,使用海綿搭配洗碗精清洗;
Silicone lunch boxes or straws have become very popular in recent years. Silicone materials are lightweight, elastic, and can also be used for microwaves. However, it should be noted that some silicone may not be heat-resistant and may be susceptible to static electricity and dust. It is recommended to use a sponge with dishwashing detergent for cleaning;
另外也有廠商推出PLA聚乳酸復(fù)合材質(zhì)的餐具,號稱是由小麥、玉米等作物提煉制成,環(huán)保又便宜,然而其實(shí)由于PLA耐熱性較差,因此部分廠商仍會添加PP或PE進(jìn)行塑形,必須注意多數(shù)此種材質(zhì)的制品耐熱性較差,清洗時(shí)也要使用中性洗潔精。
In addition, some manufacturers have launched PLA polylactic acid composite tableware, claiming to be made from crops such as wheat and corn, which is environmentally friendly and cheap. However, due to the poor heat resistance of PLA, some manufacturers still add PP or PE for shaping. It must be noted that most products made of this material have poor heat resistance, and neutral detergent should also be used for cleaning.
我們要確認(rèn)自己的用途后再選擇餐具,只有這樣才能在為地球盡一份心力的同時(shí)維持健康!
We need to confirm our purpose before choosing tableware, only in this way can we contribute our efforts to the earth while maintaining health!
有了一次性環(huán)保餐具上面的小總結(jié),希望對廣大客戶有所幫助,如果有什么不理解的或者尋求幫助的請點(diǎn)擊我們的網(wǎng)站:http://m.hydronic.cn或者來電咨詢,我們會盡全力為您解決
With the summary on disposable environmentally friendly tableware, we hope it can be helpful to our customers. If you have any questions or need help, please click on our website: http://m.hydronic.cn Or call to inquire, we will do our best to solve it for you
- 上一個(gè): 生物可降解塑料顆粒與傳統(tǒng)的塑料顆粒有什么不同?
- 下一個(gè): 生物降解塑料顆粒的使用要注意什么?
