      生物可降解塑料顆粒與傳統(tǒng)的塑料顆粒有什么不同?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2023-11-23 13:45:06
      生物可降解塑料顆粒與傳統(tǒng)的塑料顆粒不同,傳統(tǒng)的塑料在分解的過程中會(huì)釋放出有害物質(zhì),污染環(huán)境。而生物可降解塑料顆??梢栽诜纸獾倪^程中不會(huì)危害環(huán)境,對(duì)于保護(hù)環(huán)境、減少污染有著非常重要的作用。
      Biodegradable plastic particles are different from traditional plastic particles, which will release harmful substances and pollute the environment in the process of decomposition. Biodegradable plastic particles can not harm the environment during the decomposition process, playing a very important role in protecting the environment and reducing pollution.
      生物可降解塑料顆粒是由生物基材料和降解劑組成的,生物基材料是指生物來源的高分子材料,例如淀粉類、纖維素類、蛋白質(zhì)類等,而降解劑是在生物基材料中添加一定比例的添加劑,使其獲得分解的能力。
      Biodegradable plastic particles are composed of bio based materials and degradation agents. Bio based materials refer to polymer materials from biological sources, such as starch, cellulose, proteins, etc. Degradation agents add a certain proportion of additives to bio based materials to achieve their ability to decompose.
      由于生物可降解塑料顆粒具有可降解性,因此不會(huì)對(duì)土壤和水源等環(huán)境造成不可逆的影響,從而對(duì)環(huán)境保護(hù)起到了積極的作用。生物可降解塑料顆粒還可以降低生態(tài)系統(tǒng)對(duì)人類造成的損害,是設(shè)計(jì)和制造一些短期用途的產(chǎn)品的理想選擇。
      Due to the degradability of biodegradable plastic particles, they will not have irreversible effects on the environment such as soil and water sources, thus playing a positive role in environmental protection. Biodegradable plastic particles can also reduce the damage caused to humans by ecosystems, making them an ideal choice for designing and manufacturing products for short-term use.
      另外,生物可降解塑料顆粒還可以應(yīng)用于農(nóng)業(yè)和養(yǎng)殖業(yè)生產(chǎn)中。例如生產(chǎn)有機(jī)肥料、包裝農(nóng)作物等。
      In addition, biodegradable plastic particles can also be applied in agriculture and aquaculture production. For example, producing organic fertilizers, packaging crops, etc.
      生物可降解塑料顆粒在實(shí)際應(yīng)用過程中還存在一些問題。生物可降解塑料顆粒的性能相對(duì)傳統(tǒng)塑料仍有一定差距。由于在政策方面的原因,生物可降解塑料顆粒的生產(chǎn)成本相對(duì)較高。
      There are still some problems in the practical application of biodegradable plastic particles. Firstly, there is still a certain gap in the performance of biodegradable plastic particles compared to traditional plastics. Secondly, due to national policy reasons, the production cost of biodegradable plastic particles is relatively high.
      總的來說,生物可降解塑料顆粒是具有生物可降解性的材料,其性質(zhì)能夠有效地避免對(duì)環(huán)境造成影響。雖然存在著成本問題和性能差異,但生物可降解塑料顆粒在環(huán)境保護(hù)和可持續(xù)發(fā)展等方面具有無可替代的作用。
      Overall, biodegradable plastic particles are materials with biodegradability, and their properties can effectively avoid environmental impacts. Although there are cost issues and performance differences, biodegradable plastic particles play an irreplaceable role in environmental protection and sustainable development.
