      生物降解顆粒使用要注意什么事項?
      生物降解顆粒使用要注意什么事項?
      網(wǎng)址:http://m.hydronic.cn 手機頁面二維碼 2023-11-09 18:18:01
      生物降解塑料是由可生物降解物質(zhì)經(jīng)過特定工藝加工而成的一種新型環(huán)保材料,廣泛應(yīng)用于各個領(lǐng)域,如包裝、農(nóng)業(yè)、餐具等。相比于傳統(tǒng)塑料制品,生物降解塑料具有可降解、、無害、低碳排放等優(yōu)點,更符合綠色環(huán)保理念。然而,在使用生物降解塑料顆粒時,需要注意一些事項,以確保其有效使用并避免不必要的損失。
      Biodegradable plastics are a new type of environmentally friendly material processed from biodegradable substances through specific processes, widely used in various fields, such as packaging, agriculture, tableware, etc. Compared to traditional plastic products, biodegradable plastics have advantages such as biodegradability, non-toxic, harmless, and low-carbon emissions, which are more in line with the concept of green environmental protection. However, when using biodegradable plastic particles, some precautions need to be taken to ensure their effective use and avoid unnecessary losses.
      ,要防潮。因為生物降解塑料是由可生物降解物質(zhì)加工而成,其在潮濕環(huán)境下容易受潮變質(zhì),甚會影響其質(zhì)量。因此,在使用過程中,應(yīng)盡量避免將其浸泡在水中或置于潮濕環(huán)境下,同時選擇防潮性能好的包裝材料,以確保其干燥。
      Firstly, it is necessary to prevent moisture. Because biodegradable plastics are processed from biodegradable substances, they are prone to moisture deterioration and even affect their quality in humid environments. Therefore, during use, it is advisable to avoid soaking it in water or placing it in a damp environment, and to choose packaging materials with good moisture resistance to ensure its dryness.
      其次,要避免高溫環(huán)境。生物降解塑料顆粒在高溫環(huán)境下易發(fā)生變形、軟化,甚會熔化。因此,在使用過程中,應(yīng)盡量避免將其暴露在高溫環(huán)境下,選擇適當(dāng)?shù)陌b材料,并儲存于通風(fēng)、干燥、陰涼的地方。
      Secondly, avoid high temperature environments. Biodegradable plastic particles are prone to deformation, softening, and even melting in high-temperature environments. Therefore, during use, it is important to avoid exposing it to high temperatures, choose appropriate packaging materials, and store it in a ventilated, dry, and cool place.
      同時,要注意生物降解塑料顆粒的穩(wěn)定性。由于生物降解塑料顆粒的材料特性,其在長期放置、運輸?shù)冗^程中易出現(xiàn)生物降解現(xiàn)象,影響其穩(wěn)定性。因此,在使用過程中,應(yīng)合理安排使用時間,盡量避免存儲過長時間,對于已經(jīng)生物降解的顆粒,不應(yīng)再使用。
      At the same time, attention should be paid to the stability of biodegradable plastic particles. Due to the material characteristics of biodegradable plastic particles, they are prone to biodegradation during long-term storage, transportation, and other processes, which affects their stability. Therefore, during the use process, it is necessary to arrange the usage time reasonably and avoid storing for too long as much as possible. For biodegradable particles, they should not be used again.
      還有一點就是盡量選擇正規(guī)廠家的產(chǎn)品。市場上存在著一些質(zhì)量不過關(guān)的生物降解塑料顆粒產(chǎn)品,可能出現(xiàn)質(zhì)量差、易生物降解、易變質(zhì)等問題,給使用者帶來不必要的損失。因此,在選擇生物降解塑料顆粒的時候,應(yīng)選擇正規(guī)廠家生產(chǎn)的產(chǎn)品,同時提前了解產(chǎn)品的質(zhì)量、性能等信息。
      Another point is to try to choose products from legitimate manufacturers. There are some biodegradable plastic particle products with poor quality in the market, which may have problems such as poor quality, easy biodegradation, and spoilage, causing unnecessary losses to users. Therefore, when choosing biodegradable plastic particles, it is advisable to choose products produced by reputable manufacturers, while also understanding the quality, performance, and other information of the products in advance.
      需要注意的一點就是環(huán)保問題。生物降解塑料在使用過程中雖然能夠代替?zhèn)鹘y(tǒng)塑料制品,但仍需注意環(huán)保問題。生物降解塑料雖然是生物可降解的,但在某些特定環(huán)境下,如海洋的深海環(huán)境下,其降解速度也較慢。因此,在使用生物降解塑料顆粒時,應(yīng)注意垃圾分類、垃圾回收等問題,盡量減少對環(huán)境的污染。
      One thing to note is the issue of environmental protection. Although biodegradable plastics can replace traditional plastic products during use, environmental protection issues still need to be addressed. Although biodegradable plastics are biodegradable, their degradation rate is also slower in certain specific environments, such as deep-sea environments in the ocean. Therefore, when using biodegradable plastic particles, attention should be paid to issues such as garbage classification and garbage recycling to minimize environmental pollution.
      本文由可降解顆粒為您提供,我們的網(wǎng)站是:http://m.hydronic.cn我們將以全心全意的熱情為您提供服務(wù),歡迎您的訪問!
      This article is provided to you by degradable particles, and our website is: http://m.hydronic.cn We will provide you with wholehearted enthusiasm and welcome your visit!
