可降解顆粒是制作的環(huán)保降解塑料的原料
可降解顆粒是制作的環(huán)保降解塑料的原料,它主要是利用植物秸桿等制成的對人體和環(huán)境友好的物品,不同于三大合成的塑料,廢棄后,在生物環(huán)境的作用下,可以自行分解,無論對人還是環(huán)境都無害,屬于綠色包裝可降解塑料袋是“能降解、易降解”的一種一次性購物袋。
Degradable particles are the raw materials of environmentally-friendly degradable plastics, which are mainly made of plant straw and other materials that are friendly to human body and environment. They are different from the three synthetic plastics. After being discarded, they can decompose themselves under the action of the biological environment, and are harmless to both people and the environment. They belong to green packaging. Degradable plastic bags are disposable shopping bags that are "degradable and easy to degrade".
可降解塑料通過優(yōu)化選擇生產(chǎn)原料和制作工藝,在數(shù)天或幾個月的日曬雨淋及微生物的共同作用下,能逐步分解成碎片,終全部降解??山到馑芰系脑牧现饕校壕廴樗?、聚羥基脂肪酸酯、二氧化碳共聚物、淀粉、改性淀粉或其它纖維素、光敏劑、生物降解劑等。
By optimizing the selection of production materials and production process, degradable plastics can be gradually decomposed into fragments and finally completely degraded under the joint action of several days or months of sunshine, rain and microorganisms. The raw materials of degradable plastics mainly include polylactic acid, polyhydroxy fatty acid ester, carbon dioxide copolymer, starch, modified starch or other cellulose, photosensitizer, biodegradable agent, etc.
目前,可降解塑料的原材料主要有:
At present, the main raw materials of degradable plastics are:
聚乳酸(PLA),它是由植物糖分提取的丙交酯單體聚合而成,在工業(yè)堆肥下可完全降解為水和二氧化碳。
Polylactic acid (PLA), which is polymerized from lactide monomer extracted from plant sugar, can be completely degraded into water and carbon dioxide under industrial composting.
聚羥基脂肪酸酯(PHA),聚羥基脂肪酸酯(PHA)是由微生物通過各種碳源發(fā)酵而合成的不同結(jié)構(gòu)的脂肪族共聚聚酯,不僅能夠用于包裝材料、農(nóng)膜等,還能廣泛的應(yīng)用于藥品、化妝品、動物飼料等領(lǐng)域。
Polyhydroxy fatty acid ester (PHA) and polyhydroxy fatty acid ester (PHA) are aliphatic copolyesters with different structures synthesized by microorganisms through fermentation of various carbon sources. They can be used not only in packaging materials, agricultural films, but also in medicine, cosmetics, animal feed and other fields.
二氧化碳共聚物(PPC),外觀與聚乙烯塑料相似,彈性良好,在土壤中可在短時間內(nèi)完全降解,并直接被植物吸收利用。
Carbon dioxide copolymer (PPC), similar in appearance to polyethylene plastic, has good elasticity, can be completely degraded in soil in a short time, and can be directly absorbed by plants.
其他添加劑,在塑料包裝制品的生產(chǎn)過程中加入一定量的添加劑(如淀粉、改性淀粉或其它纖維素、光敏劑、生物降解劑等),使塑料的穩(wěn)定性下降,較容易在自然環(huán)境中降解。
Other additives: add a certain amount of additives (such as starch, modified starch or other cellulose, photosensitizer, biodegradable agent, etc.) in the production process of plastic packaging products to reduce the stability of plastics and make them easier to degrade in the natural environment.
關(guān)于“可降解顆粒是制作的環(huán)保降解塑料的原料”這一內(nèi)容就講解到這里了,您對此還有不明白的地方隨時可以來我們網(wǎng)站http://m.hydronic.cn進行咨詢了解!
That's all about "degradable particles are the raw materials of environmentally friendly degradable plastics". If you have any questions about this, please come to our website at any time http://m.hydronic.cn Consult and understand!
