      一次性環(huán)保餐具本身具備怎樣的功能特色?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2023-02-08 14:48:30
      一次性環(huán)保餐具是指一次性使用的包裝物品用的盒子,這種包裝盒盡管叫一次性包裝盒,但因?yàn)槠滟|(zhì)料,包裝盒能夠重復(fù)多次使用,現(xiàn)在市場上的一次性包裝盒大多是由橡膠注塑工藝一次性成型的一次性包裝盒。
      Disposable environment-friendly tableware refers to the box for disposable packaging items. Although this kind of packaging box is called disposable packaging box, because of its material, the packaging box can be reused for many times. Now, most of the disposable packaging boxes on the market are disposable packaging boxes formed by rubber injection molding process.
      一次性環(huán)保注塑餐盒為PP資料。PP的密度小、強(qiáng)度、剛度、硬度耐熱性均優(yōu)于低壓聚乙烯,耐120攝氏度高溫,-20攝氏度低溫。常見的酸、堿有機(jī)溶劑對它幾乎不起作用,可用于食具。PP是一種半結(jié)晶性資料,它比PE要更堅固并且有更高的熔點(diǎn),放在水里煮也是沒有問題的。
      Disposable environment-friendly injection molding lunch box is PP data. PP has lower density, strength, rigidity, hardness and heat resistance than low pressure polyethylene, and can withstand 120 ℃ high temperature and - 20 ℃ low temperature. Common acid and alkali organic solvents have little effect on it and can be used for tableware. PP is a semi-crystalline material, which is stronger and has a higher melting point than PE, and it is no problem to boil it in water.
      一般的一次性餐盒都是選用食品級PP資料的,PP塑料是不吸收微波的,因而它能夠在微波爐內(nèi)做烹調(diào)器皿。一次性環(huán)保注塑餐盒不只方便有用,而且能夠?qū)⑹澄锓珠T別類地寄存,也可疊放在一起。
      General disposable lunch boxes are made of food-grade PP materials. PP plastic does not absorb microwave, so it can be used as cooking utensils in the microwave oven. Disposable environment-friendly injection molding lunch box is not only convenient and useful, but also can store food in different categories, and can also be stacked together.
      如何選購定心的餐盒成為許多消費(fèi)者關(guān)切的問題。購買時要留意以下幾點(diǎn):
      How to choose and buy a centering lunch box has become a concern of many consumers. Pay attention to the following points when purchasing:
      看密封性。一般餐盒應(yīng)密封在塑料包裝袋中,包裝袋不該有破損,包裝不嚴(yán)密的餐盒容易受到環(huán)境的污染,衛(wèi)生得不到保證。
      Check the tightness. Generally, the lunch box should be sealed in a plastic packaging bag. The packaging bag should not be damaged. The lunch box that is not tightly packed is vulnerable to environmental pollution and sanitation cannot be guaranteed.
      看外包裝,要仔細(xì)檢查包裝標(biāo)志上是否標(biāo)示了"產(chǎn)品名稱、生產(chǎn)者廠名、廠址、產(chǎn)品履行規(guī)范、生產(chǎn)日期、保質(zhì)期、衛(wèi)生許可證"等規(guī)定要標(biāo)示的內(nèi)容,如果標(biāo)志內(nèi)容標(biāo)示不全或許不規(guī)范,則這樣的餐盒就不要購買了。
      When looking at the outer packaging, carefully check whether the packaging marks are marked with "product name, manufacturer's factory name, factory address, product performance specification, production date, shelf life, hygiene license" and other contents required to be marked. If the contents of the marks are incomplete or not standardized, such lunch boxes should not be purchased.
      看盒身,餐盒盒身的色澤應(yīng)均勻、概括清晰,盒口不該有顯著的洼陷、起皺。看盒口,留意盒口平整、潤滑,無廢邊、毛刺,杯身應(yīng)清潔通明,厚薄均勻,無雜質(zhì)、氣泡、水紋,無魚眼僵塊等現(xiàn)象。
      Look at the box body. The color of the box body should be uniform and clear, and the mouth of the box should not have obvious depressions and wrinkles. Look at the box mouth, pay attention to the smoothness and lubrication of the box mouth, without waste edges and burrs. The cup body should be clean and bright, with uniform thickness, without impurities, bubbles, water marks, and fish eye block.
      一次性餐盒均選擇契合環(huán)保PP新資料,PP塑料餐盒(用質(zhì)料出產(chǎn)、透明)因?yàn)榫哂?、無色、無臭、熔點(diǎn)較高、可塑性高、可回收、包裝密封度好、出產(chǎn)簡便及相對成本較低一級特色,因而成了制作一次性快餐盒的主流資料。您有需求就來我們網(wǎng)站http://m.hydronic.cn進(jìn)行咨詢了解吧!
      Disposable lunch boxes are selected to fit the new information of environment-friendly PP. PP plastic lunch boxes (produced with materials and transparent) have become the mainstream material for making disposable fast food boxes because of their non-toxic, colorless, odorless, high melting point, high plasticity, recyclability, good packaging tightness, simple production and low relative cost. Come to our website if you need http://m.hydronic.cn Consult and understand!
