一次性餐飲具選用有三點(diǎn)講究
一次性餐飲具通常分為塑料和紙兩種材質(zhì),常見(jiàn)的一次性塑料餐飲具包括碗、杯、刀叉勺和吸管等,一次性紙餐飲具包括紙杯、紙碗、紙餐盒等。那么,如何選購(gòu)一次性餐具呢?有哪些注意事項(xiàng)呢?下面一次性環(huán)保餐具廠家為您講解。
Disposable tableware is usually made of plastic and paper. Common disposable plastic tableware includes bowls, cups, knives, forks, spoons and straws. Disposable paper tableware includes paper cups, paper bowls, paper lunch boxes, etc. So, how to choose disposable tableware? What are the precautions? The manufacturer of disposable environment-friendly tableware will explain it to you.
查看外觀和標(biāo)識(shí)
View appearance and logo
一次性餐飲具(包括塑料和紙材質(zhì))均屬于生產(chǎn)許可證管理范圍內(nèi)。選購(gòu)時(shí),消費(fèi)者應(yīng)仔細(xì)查看包裝是否有qs標(biāo)志、適用溫度、保質(zhì)期等信息。盡量選擇色澤均勻、表面平整、邊緣光滑、沒(méi)有裝飾圖案的一次性餐飲具。
Disposable catering utensils (including plastic and paper materials) are within the scope of production license management. When purchasing, consumers should carefully check whether the package has information such as qs mark, applicable temperature and shelf life. Try to choose disposable tableware with uniform color, flat surface, smooth edge and no decorative pattern.
避免購(gòu)買(mǎi)太軟的產(chǎn)品
Avoid buying too soft products
杯身挺度不好的紙杯或塑料杯捏起來(lái)很軟,負(fù)重性能往往不達(dá)標(biāo)。倒入水或飲料后,端起來(lái)時(shí)會(huì)嚴(yán)重變形,有的甚端不起來(lái),如果盛裝開(kāi)水的話,容易造成燙傷。
Paper cups or plastic cups with poor stiffness are very soft when pinched, and their weight bearing performance is often not up to standard. After water or drink is poured in, it will be severely deformed when it is lifted, and some can not even be lifted. If boiled water is filled, it is easy to cause burns.
注意區(qū)分材質(zhì)和用途
Pay attention to distinguish between materials and uses
紙杯一般會(huì)標(biāo)注是否可以盛裝熱飲,有些冷飲杯、冰淇淋杯表面涂有食用蠟,當(dāng)盛裝的熱飲溫度超過(guò)70℃時(shí),紙杯表面蠟層容易融化并混入食品中,影響口感和衛(wèi)生。
Paper cups generally indicate whether hot drinks can be contained. Some cold drink cups and ice cream cups are coated with edible wax. When the temperature of hot drinks exceeds 70 ℃, the wax layer on the surface of paper cups is easy to melt and mix with food, affecting the taste, health and safety.
塑料杯底部都會(huì)有個(gè)三角數(shù)字符號(hào),它代表了杯子是什么材料制成和使用條件,市面上一次性塑料杯一般是pp(編號(hào)5)和ps(編號(hào)6)兩種材質(zhì)。
There will be a triangle number symbol at the bottom of the plastic cup, which represents what material the cup is made of and the conditions for use. The disposable plastic cup on the market is generally made of pp (No. 5) and ps (No. 6).
pp(聚丙烯)材質(zhì),能耐130℃左右的高溫,正常使用下可以盛裝沸水、熱飲。ps(聚苯乙烯)材質(zhì)一般用來(lái)盛裝冷飲或者溫?zé)岬娘嬈贰?/div>
PP (polypropylene) is safe and non-toxic, and can withstand a high temperature of about 130 ℃. It can contain boiling water and hot drinks under normal use. Ps (polystyrene) material is generally used to hold cold drinks or warm drinks.
一次性餐飲具選用有三點(diǎn)講究就是以上內(nèi)容了,您對(duì)此有什么了解嗎?當(dāng)然您在購(gòu)買(mǎi)時(shí)也不要把作為決定性因素來(lái)看。更多相關(guān)內(nèi)容就來(lái)我們網(wǎng)站http://m.hydronic.cn咨詢(xún)吧!
Three points should be paid attention to in the selection of disposable tableware. What do you know about this? Of course, you should not take the price as a decisive factor when purchasing. More relevant content will come to our website http://m.hydronic.cn Consult!
- 上一個(gè): 玉米淀粉餐具和可降解餐具有三方面的區(qū)別
- 下一個(gè): 玉米淀粉顆??山到獠秃谐尚陀龅絾?wèn)題
