      有關(guān)玉米淀粉顆粒的詳細(xì)介紹
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2022-09-24 15:44:18
      玉米淀粉可降解餐具,是采用玉米淀粉及植物纖維為基料,輔之以生物聚酯、多元醇等物質(zhì)加工而成,其淀粉含量高可達(dá)80%,在土壤和自然環(huán)境下可以自然降解,對環(huán)境沒污染、無破害。節(jié)約了石油等資源,經(jīng)檢測部門檢測,各項(xiàng)衛(wèi)生理化指標(biāo)均達(dá)到標(biāo)準(zhǔn),是餐飲市場上普遍使用的理想替代品。
      Corn starch degradable tableware is made of corn starch and plant fiber as the base material, supplemented by biological polyester, polyols and other substances. Its starch content can reach 80%, which can be naturally degraded in soil and natural environment, without pollution and damage to the environment. It saves oil and other resources. After testing by the national testing department, all health physical and chemical indicators have reached the national standards. It is an ideal substitute widely used in the catering market.
      一般是改性淀粉與生物降解聚酯(如PLA/PBAT/PBS/PHA/PPC等)的共混物,它能夠完全生物降解,可堆肥,對環(huán)境沒污染,廢棄物適合堆肥、填埋等處理方式。以淀粉為基礎(chǔ)的生物基塑料一般是改性淀粉與聚烯烴(如PP/PE/PS等)的混合物。
      Generally, it is a blend of modified starch and biodegradable polyester (such as PLA/PBAT/PBS/PHA/PPC, etc.). It can be completely biodegradable, compostable, and does not pollute the environment. Waste is suitable for composting, landfill and other treatment methods. Starch based bio based plastics are generally a mixture of modified starch and polyolefins (such as PP/PE/PS).
      玉米淀粉顆粒的環(huán)保意義在于能夠減少石化資源的使用,減少二氧化碳排放,廢棄物適合焚燒處理。這兩種材料都可以代替?zhèn)鹘y(tǒng)石油基塑料,廣泛用于塑料包裝材料、防震材料、塑料膜及塑料袋、一次性餐飲具、食品容器、玩具等。
      Its environmental significance is to reduce the use of petrochemical resources, reduce carbon dioxide emissions, and waste is suitable for incineration. These two materials can replace traditional petroleum based plastics and are widely used in plastic packaging materials, shock proof materials, plastic films and bags, disposable tableware, food containers, toys, etc.
      與傳統(tǒng)塑料制品相比,淀粉基材料及制品的優(yōu)勢表現(xiàn)
      Compared with traditional plastic products, the advantages of starch based materials and products
      1、性能相近:具有與同類傳統(tǒng)塑料制品相同和相近的使用性能;
      1. Similar performance: it has the same and similar performance with similar traditional plastic products;
      2、環(huán)保:淀粉基生物基塑料及制品具有節(jié)約石油資源、減少二氧化碳排放的優(yōu)勢;淀粉基生物降解塑料及制品具有完全生物降解、可堆肥,實(shí)現(xiàn)垃圾無害化處理的優(yōu)勢;
      2. Environmental protection: starch based bio based plastics and products have the advantages of saving oil resources and reducing carbon dioxide emissions; Starch based biodegradable plastics and products have the advantages of complete biodegradation, compostability and harmless garbage treatment;
      3、無有害物質(zhì):淀粉基材料及制品不含塑化劑、雙酚A、重金屬等有毒有害物質(zhì);
      3. No harmful substances: starch based materials and products do not contain plasticizers, bisphenol A, heavy metals and other toxic and harmful substances;
      4、生產(chǎn)工藝:生產(chǎn)過程無三廢排放,不會對環(huán)境造成新的污染;
      4. Production process: there is no discharge of three wastes in the production process, which will not cause new pollution to the environment;
      5、成本:淀粉基生物基塑料料及制品與普通石油塑料制品持平,淀粉基全生物降解材料及制品的成本約是普通石油塑料的兩倍。
      5. Cost: The cost of starch based bio based plastic materials and products is the same as that of ordinary petroleum plastic products. The cost of starch based fully biodegradable materials and products is about twice that of ordinary petroleum plastics.
      以上就是為大家介紹的有關(guān)玉米淀粉顆粒的詳細(xì)介紹,希望能夠給您好的幫助,更多相關(guān)內(nèi)容就來我們網(wǎng)站http://m.hydronic.cn咨詢了解吧!
      The above is a detailed introduction of corn starch granules for you. I hope it can help you. More relevant content will come to our website http://m.hydronic.cn Ask and understand!
