      玉米淀粉顆??山到庑圆途叩目蓪嵱眯?/b>
      玉米淀粉顆??山到庑圆途叩目蓪嵱眯?/h1>
      網(wǎng)址:http://m.hydronic.cn 手機頁面二維碼 2022-08-08 16:31:52
      玉米淀粉顆粒基生物降解性餐具是人類生存環(huán)保的無公害綠色產(chǎn)品,國內(nèi)政策大力支持。那么對于這種產(chǎn)品您了解多少呢?
      Corn starch granule based biodegradable tableware is a pollution-free green product for human survival and environmental protection, which is strongly supported by domestic policies. How much do you know about this product?
      玉米淀粉顆粒近年市場上的一次性打包盒已由泡沫飯盒轉(zhuǎn)向環(huán)保飯盒,原來的泡沫打包盒由于不耐高溫,且制作過程對環(huán)境造成破壞而備受淘汰,取而待之的有塑料飯盒,紙制飯盒,木制飯盒,降解飯盒…等等。其中,塑料由於具毒性較低、熔點較高、可塑性強、生產(chǎn)簡便及相對成本較低等特點,因而成了制造一次性快餐盒的主流材料。
      In recent years, the disposable packaging boxes of corn starch granules in the market have been changed from foam lunch boxes to environmental protection lunch boxes. The original foam packaging boxes have been eliminated because they are not resistant to high temperature and the production process has caused damage to the environment. Plastic lunch boxes, paper lunch boxes, wooden lunch boxes, degradable lunch boxes, etc. are taken instead. Among them, plastic has become the mainstream material for manufacturing disposable fast food boxes due to its low toxicity, high melting point, strong plasticity, simple production and low relative cost.
      玉米淀粉餐具是生物降解制品,以玉米淀粉顆粒為主要原料,經(jīng)高科技生產(chǎn)工藝加工而成,自然條件才可自行降解,避免了對環(huán)境的污染,節(jié)約了石油等不可在生資源,經(jīng)權(quán)威檢測部門檢測,各項衛(wèi)生理化指標(biāo)均達到標(biāo)準(zhǔn),是目前餐飲市場上普遍使用卻飽受爭議的“餐具”的理想替代品。
      Corn starch tableware is a biodegradable product. It is made of corn starch granules as the main raw material and processed by high-tech production technology. It can be degraded under natural conditions, avoiding environmental pollution and saving oil and other non living resources. After being tested by the national authoritative testing department, all the sanitary and physical and chemical indicators meet the national standards. It is an ideal substitute for the widely used but controversial "sterilized tableware" in the catering market.
      由于它是玉米淀粉和其他環(huán)保材料精制而成,不含對人體有害的物質(zhì),可放心長期使用。零污染產(chǎn)品埋入泥土中,在適宜的溫度下,90天后可降解形成二氧化碳和水,對土壤和空氣不造成污染。
      Because it is refined from corn starch and other environmental protection materials, it does not contain substances harmful to human body, and can be used safely for a long time. The zero pollution product is buried in the soil and can be degraded to form carbon dioxide and water after 90 days at a suitable temperature, without causing pollution to the soil and air.
      玉米淀粉是可再生資源,取之不盡,用之不竭,而紙質(zhì)餐具和塑料餐具需大量的木材和石油化工產(chǎn)品。以玉米淀粉為原料可節(jié)省大量的石油和森林資源。品質(zhì)高產(chǎn)品密織性好,耐水、耐油、防滲透,同時具有良好的耐高溫和耐低溫性,適合冰箱冷凍、冷藏、保鮮食品,微波爐加熱等。
      Corn starch is a renewable resource, which is inexhaustible. Paper tableware and plastic tableware require a large amount of wood and petrochemical products. Using corn starch as raw material can save a lot of oil and forest resources. High quality products have good density, water resistance, oil resistance and anti penetration, and have good high temperature and low temperature resistance. They are suitable for freezing, cold storage, fresh food, microwave heating, etc.
      通常在使用的過程中我們基本上都不會在意餐具是不是被進行清洗,只是簡單的通過肉眼來觀察表面是不是清潔無異而已。其實大多數(shù)的餐具都是通過家庭小作坊來進行處理的,基本上都是不干凈的為了降低生產(chǎn)成本并沒有嚴格按照餐具清潔流程來完成的。而還有一些一次性餐具產(chǎn)品也是比較常見的產(chǎn)品相比于餐具會更加的干凈衛(wèi)生。
      Generally, we don't care whether the tableware is disinfected or not during the use process, but simply observe whether the surface is clean with the naked eye. In fact, most of the disinfected tableware are disinfected by small family workshops, which are basically unclean. In order to reduce the production cost, the disinfection and cleaning process of disinfected tableware is not strictly followed. And some disposable tableware products are also more common products, which will be more clean and hygienic than sterilized tableware.
      玉米淀粉顆粒可降解性餐具的可實用性問題的相關(guān)內(nèi)容就是這樣了,如果您對此有什么不了解的,可以隨時來我們網(wǎng)站http://m.hydronic.cn進行咨詢。
      This is the relevant content of the practicality of corn starch granule degradable tableware. If you don't know anything about this, you can come to our website at any time http://m.hydronic.cn Consult.
