      一種玉米淀粉基生物降解一次性餐飲具的生產(chǎn)
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2022-08-05 15:44:49
      一種玉米淀粉基生物降解一次性餐飲具,以食用玉米淀粉為主料,與一定比例的增塑劑和填加劑經(jīng)高速共混改性、擠出、壓片、成型制得。下面玉米淀粉顆粒生產(chǎn)廠家來為您講講相關(guān)的原理內(nèi)容吧。
      The invention relates to a corn starch based biodegradable disposable tableware, which is prepared by high-speed blending modification, extrusion, tablet pressing and molding with edible corn starch as the main material and a certain proportion of plasticizer and filler. Next, the manufacturers of corn starch granules will talk about the relevant principles for you.
      其原料含量(按重量比)為:食品級玉米淀粉60-85%,食品級增塑劑10-20%,再加入適量的食品級填加劑。其工藝流程為:配料、高速混料改性、擠出壓片、成型、紫外線和密封包裝。
      Its raw material content (by weight ratio) is: food grade corn starch 60-85%, food grade plasticizer 10-20%, and then add an appropriate amount of food grade additives. The technological process includes: batching, high-speed mixing modification, extrusion and tablet pressing, molding, ultraviolet disinfection and sealed packaging.
      優(yōu)點:
      advantage:
      可降解:在自然界(光和土壤)中具有可自然降解的特性.
      Degradable: it has the characteristics of natural degradation in nature (light and soil)
      強(qiáng)度好:可滿足消費(fèi)者使用需求。
      Good strength: it can meet the needs of consumers.
      不滲漏:密封性能好,不滲漏。
      No leakage: good sealing performance, no leakage.
      無異味:以玉米淀粉為原料,產(chǎn)品帶有淡淡的爆米花清香。
      No odor: with corn starch as raw material, the product has a faint smell of popcorn.
      耐溫性:可耐高溫150℃、低溫-40℃,在微波爐和冰箱中亦可放心使用。
      Temperature resistance: it can withstand high temperature of 150 ° C and low temperature of - 40 ° C. It can also be safely used in microwave ovens and refrigerators.
      抗油脂性:能夠耐受食物中的大量油脂。
      Grease resistance: able to tolerate a large amount of grease in food.
      產(chǎn)品優(yōu)勢:
      Product advantages:
      淀粉的——原料天然:以天然玉米淀粉為原料,可持續(xù)供應(yīng),使天然資源重復(fù)使用,循環(huán)不息。
      Starch - raw materials are natural: natural corn starch is used as raw materials for sustainable supply, so that natural resources can be reused and recycled.
      降解的——可降解:原料為天然高分子化合物,能在自然環(huán)境下實現(xiàn)降解。
      Degradable - safe and degradable: the raw material is natural polymer compound, which can be degraded in the natural environment.
      環(huán)保的——綠色環(huán)保:產(chǎn)品使用后在自然環(huán)境中能快速被微生物降解,成為植物養(yǎng)料,真正做到源于自然,還于自然,有效解決白色污染帶來的環(huán)境破壞。
      Environmental protection - green environmental protection: after use, the product can be quickly degraded by microorganisms in the natural environment and become plant nutrients. It can truly come from nature and return to nature, and effectively solve the environmental damage caused by white pollution.
      健康的——害性:原料天然,生產(chǎn)過程無菌生產(chǎn),檢驗嚴(yán)格,產(chǎn)品降解后不會對土壤及空氣產(chǎn)生毒害,無二次污染的危害。
      Healthy - non toxic: the raw materials are natural, the production process is aseptic, and the disinfection inspection is strict. The product will not be toxic to the soil and air after degradation, and there is no harm of secondary pollution.
      低碳的——替代性強(qiáng):可替代以石油為原料的塑料制品和以木材為原料的紙制品。
      Low carbon - strong substitutability: it can replace plastic products with petroleum as raw materials and paper products with wood as raw materials.
      標(biāo)準(zhǔn):完全符合“4R+1D”環(huán)保標(biāo)準(zhǔn)(4R:低消耗、綠色材料、可循環(huán)利用、往復(fù)生產(chǎn)、1D:可降解)。
      International standards: fully comply with the "4R + 1D" international environmental protection standards (4R: low consumption, green materials, recyclable, reciprocating production, 1D: degradable).
      玉米淀粉基餐具玉米淀粉基降解環(huán)保餐具,是采用天然玉米淀粉及植物纖維為基料,輔之以生物聚酯、多元醇等物質(zhì)加工而成,其淀粉含量高可達(dá)80%,在土壤和自然環(huán)境下可以自然降解,對環(huán)境無污染、無破害。節(jié)約了石油等資源,經(jīng)權(quán)威檢測部門檢測,各項衛(wèi)生理化指標(biāo)均達(dá)到標(biāo)準(zhǔn),是目前餐飲市場上普遍使用卻飽受爭議的“餐具”的理想替代品。
      Corn starch based tableware corn starch based degradable environment-friendly tableware is made of natural corn starch and plant fiber as the base material, supplemented by biological polyester, polyol and other materials. Its starch content is as high as 80%, which can be naturally degraded in soil and natural environment, without pollution and damage to the environment. It saves oil and other non renewable resources. After being tested by the national authoritative testing department, all sanitary physical and chemical indicators meet the national standards. It is an ideal substitute for the widely used but controversial "sterilized tableware" in the catering market.
      該一次性餐飲具,、衛(wèi)生、具有一定的機(jī)械強(qiáng)度和耐溫性能,完全可以滿足餐飲具的使用要求,同時,廢棄物可綜合利用,生產(chǎn)過程中不產(chǎn)生三廢污染,成本相對較低,能自然降解,生物降解速度快,是一種非常理想的環(huán)保材料!更多事項就來我們網(wǎng)站http://m.hydronic.cn咨詢了解吧。
      This disposable tableware is safe, hygienic, has a certain mechanical strength and temperature resistance, and can fully meet the use requirements of tableware. At the same time, the waste can be comprehensively utilized. There is no three wastes pollution in the production process, the cost is relatively low, it can be naturally degraded, and the biological degradation speed is fast. It is a very ideal environmental protection material! Come to our website for more information http://m.hydronic.cn Consult and understand.
