可降解顆粒本身有一種突出的特性
如今可降解材料顯得甚為重要,它的實(shí)現(xiàn)方法又有多種,如采用天然的成分加工等,也都是該材料的特性,那么可降解顆粒本身有一種突出的特性是怎樣的。
Now the degradable material is very important, and there are many ways to achieve it, such as the use of natural ingredients processing, etc., are also the characteristics of the material, so the degradable particle itself has a kind of outstanding characteristics.
可降解顆粒材料不同于早期塑料制品,可降解顆粒材料的生產(chǎn)不依賴于石油,它主要是從生物中提煉得到??山到忸w粒材料可以在自然環(huán)境中自行分解,能有效減少環(huán)境污染。
Unlike earlier plastics, the production of biodegradable granular materials does not rely on petroleum, but is mainly derived from living things. Degradable granular materials can decompose themselves in natural environment and effectively reduce environmental pollution.
可降解塑料顆粒就是利用廢舊塑料加工成的顆粒。用途:日常日子中,可降解塑料顆粒可用來(lái)制造各種塑料袋、桶、盆、玩具、家具、文具等日子用具及各種塑料制品。服裝工業(yè)方面:可降解塑料顆??捎脕?lái)制造服裝、領(lǐng)帶、紐扣、拉鏈。
Degradable plastic particles are processed from waste plastics. Usage: In daily life, degradable plastic particles can be used to manufacture all kinds of plastic bags, buckets, basins, toys, furniture, stationery and other daily utensils and all kinds of plastic products. Clothing industry: degradable plastic particles can be used to make clothing, ties, buttons, zippers.
可降解塑料顆??捎脕?lái)制造各種建筑構(gòu)件、建筑東西、塑料門(mén)窗、泥灰桶??捎糜谥圃鞕C(jī)器零部件,各種形式的軸承、齒輪、凸輪、異輪、密封環(huán)、各種葉片、各種水泵葉輪?;瘜W(xué)工業(yè)方面:可降解塑料顆粒可用來(lái)應(yīng)作反應(yīng)釜、管道、容器、泵、閥門(mén)等,應(yīng)用在處理腐蝕磨損的化工出產(chǎn)場(chǎng)所。
Degradable plastic particles can be used to make all kinds of building components, building objects, plastic doors and Windows, stucco buckets. Can be used to manufacture machine parts, various forms of bearings, gears, cams, different wheels, sealing rings, all kinds of blades, all kinds of pump impeller. Chemical industry: degradable plastic particles can be used as reactors, pipes, containers, pumps, valves, etc., used in chemical production sites to deal with corrosion and wear.
可降解顆粒可作為可降解塑料使用,這是指其制品的各項(xiàng)性能可滿足使用性能要求,在保存期內(nèi)性能不變,而使用后在自然環(huán)境條件下能降解成對(duì)環(huán)境無(wú)害的物質(zhì)的塑料。塑料降解一般有兩種方式:光氧降解和生物降解,生物降解是目前認(rèn)可并采取的主要降解方式。
Degradable particles can be used as degradable plastics, which means that the properties of its products can meet the performance requirements, the performance is unchanged in the preservation period, and after use in natural environmental conditions can degrade a pair of environmentally friendly substances of plastic. Plastic degradation generally has two ways: photooxygen degradation and biodegradation, biodegradation is recognized and adopted the main way of degradation.
可降解顆粒本身有一種突出的特性相關(guān)內(nèi)容便是這樣了,如果您還想了解更多內(nèi)容就來(lái)網(wǎng)站m.hydronic.cn咨詢吧!
Degradable particles themselves have a prominent characteristic of the relevant content is such, if you still want to know more about the website m.hydronic.cn consultation!
- 上一個(gè): 一次性玉米淀粉餐具表面有劃痕能用嗎?
- 下一個(gè): 玉米淀粉顆粒本身改性以及主要特點(diǎn)不錯(cuò)
