      一次性玉米淀粉餐具表面有劃痕能用嗎?
      一次性玉米淀粉餐具表面有劃痕能用嗎?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2022-04-29 14:53:07
        一次性玉米淀粉餐具如今在市場(chǎng)中是比較受歡迎的,不僅環(huán)保而且美觀,當(dāng)然有時(shí)候也會(huì)發(fā)現(xiàn)問(wèn)題存在,比如說(shuō)它的表面有劃痕了,這樣的餐具還能使用嗎?
        Disposable cornstarch tableware is now more popular in the market, not only environmentally friendly and beautiful, of course, sometimes there are problems, such as scratches on its surface, can such tableware still be used?
        如果將劃傷的餐具用于酸性和高溫食品,很可能會(huì)沉淀出重金屬等有害物質(zhì)。如果使用劣質(zhì)、不合格的一次性玉米淀粉餐具,有害物質(zhì)會(huì)沉淀出來(lái),隨食物一起進(jìn)入人體,久而久之會(huì)引起慢性中毒。
        If damaged tableware is used in acidic and high-temperature food, it is likely to precipitate harmful substances such as heavy metals. If the use of inferior, unqualified disposable cornstarch tableware, harmful substances will precipitate out, along with the food into the human body, over time will cause chronic poisoning.
        由于釉面陶瓷中的鉛化合物可以被酸溶解,所以當(dāng)食物接觸餐具時(shí),鉛可能會(huì)被食物中的有機(jī)酸溶解。提醒一下,在使用新器具之前,請(qǐng)嘗試將它們煮沸幾分鐘進(jìn)行,然后在室溫下將它們浸泡在醋中幾個(gè)小時(shí)。因此,不應(yīng)使用有劃痕的一次性玉米淀粉餐具。使用前須在沸水中煮一段時(shí)間,或在沸水中煮沸,以防止接觸感染。
        Because lead compounds in glazed ceramics can be dissolved by acids, lead may be dissolved by organic acids in food when it comes into contact with cutlery. As a reminder, before using new appliances, try boiling them for a few minutes to disinfect them, then soaking them in vinegar at room temperature for a few hours. Therefore, disposable cornstarch cutlery with scratches should not be used. Boil in boiling water for a period of time before use, or boil in boiling water, to prevent contact with infection.
        另外需要注意的是,通常每個(gè)餐具生產(chǎn)廠家都會(huì)在其生產(chǎn)的產(chǎn)品上印上公司的標(biāo)志、日期、保質(zhì)期等。如果酒店內(nèi)有銷(xiāo)售一次性玉米淀粉餐具的人員,一定要檢查餐具是否合格。一旦檢測(cè)到一次性玉米淀粉餐具不合格,就須進(jìn)行處理。一旦發(fā)現(xiàn)所使用的餐具不合格,一定要立即停止使用,然后進(jìn)行檢查。
        In addition, it should be noted that usually every tableware manufacturer will be in its production of products printed on the company's logo, date, shelf life, etc If there are people in the hotel who sell disposable cornstarch cutlery, be sure to check the cutlery is up to standard. Once unqualified disposable cornstarch tableware is detected, it must be disposed of. Once found using substandard cutlery, be sure to immediately stop using, and then check.
        一次性玉米淀粉餐具表面有劃痕能用嗎?看完以上的講解內(nèi)容,我們知道了有劃痕一類(lèi)問(wèn)題存在餐具是不應(yīng)當(dāng)購(gòu)買(mǎi)使用的,使用起來(lái)容易出事故。更多內(nèi)容就來(lái)網(wǎng)站m.hydronic.cn咨詢(xún)吧。
        Can disposable cornstarch tableware have scratches on its surface? After reading the above explanation, we know that there is a scratch class of tableware should not be bought and used, it is easy to use accidents. For more information, visit m.hydronic.cn.
