      一次性環(huán)保可降解餐具常見(jiàn)的一些疑問(wèn)?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2021-10-08 15:47:41
      一、一次性可降解餐盒中使用的原料成分以及各自的配比是多少?
      1、 What are the ingredients used in disposable degradable lunch boxes and their respective proportions?
      常規(guī)餐盒一般按照70%-90%甘蔗纖維+10%-30%竹漿纖維為配比。不同餐具也會(huì)根據(jù)產(chǎn)品形狀、角度、硬度、挺度,調(diào)整不同纖維配比,當(dāng)然也會(huì)根據(jù)需要添加小麥秸稈、麥草、蘆葦?shù)戎参锢w維。全部使用植物纖維制成,不添加PP、PET等化學(xué)材料。
      The ratio of 70% - 90% sugarcane fiber + 10% - 30% bamboo pulp fiber is generally used for conventional lunch boxes. Different tableware will also adjust different fiber ratio according to product shape, angle, hardness and stiffness. Of course, plant fibers such as wheat straw, wheat straw and reed will be added as needed. All are made of plant fiber without adding PP, pet and other chemical materials.
      二、一次性紙漿餐盒如何達(dá)到防水防油效果?
      2、 How to achieve waterproof and oil proof effect of disposable pulp lunch box?
      紙漿模塑餐盒會(huì)添加一定食品級(jí)助劑,一般防水劑:1.0%-2.5%,防油劑:0.5%-0.8%,達(dá)到防水防油的效果。測(cè)試一般是100℃的水,120℃的油,測(cè)試時(shí)間為30分鐘;特殊要求可做把油溫和測(cè)試時(shí)間延長(zhǎng)。
      Certain food grade additives will be added to the pulp molded lunch box, generally waterproof agent: 1.0% - 2.5%, oil proof agent: 0.5% - 0.8%, so as to achieve the effect of waterproof and oil proof. The test is generally 100 ℃ water and 120 ℃ oil, and the test time is 30 minutes; Special requirements can extend the oil temperature test time.
      關(guān)于紙漿模塑一次性環(huán)??山到獠途叩某R?jiàn)8大疑問(wèn)
      Eight common questions about pulp molded disposable environmental friendly degradable tableware
      三、可降解一次性餐具產(chǎn)品含氟嗎?
      3、 Do degradable disposable tableware products contain fluorine?
      目前市面上植物纖維餐具中的防油劑大都是含氟的,防水不防油的餐具是不含氟的。
      At present, most of the oil proofing agents in the vegetable fiber tableware on the market are fluorine-containing, and the tableware that is waterproof but not oil-proof is fluorine-free.
      如果要求可降解餐具不含氟且防水防油,目前比較好的替代方案是覆膜,PBAT是目前紙漿模塑環(huán)保餐具中應(yīng)用范圍更廣、使用更多的復(fù)合材料。
      If degradable tableware is required to be fluorine-free, waterproof and oil-proof, at present, the better alternative is film coating. PBAT is the composite material with the widest application range and the most use in pulp molded environmental protection tableware.
      覆膜后的產(chǎn)品可以更好的保溫,減少溫度通過(guò)模塑產(chǎn)品的氣孔散熱,同時(shí)可以減少米飯、水餃等食物的粘粘,很大程度上可以減少防水劑和防油劑的使用。
      The coated products can better keep warm, reduce the temperature and dissipate heat through the pores of molded products. At the same time, it can reduce the stickiness of rice, dumplings and other foods, and greatly reduce the use of waterproof and oil proof agents.
      四、環(huán)保紙漿餐具多長(zhǎng)時(shí)間可以完全降解?
      4、 How long can environmentally friendly pulp tableware be completely degraded?
      在沒(méi)有任何工業(yè)分解機(jī)的情況下,紙漿模塑環(huán)保餐具在填埋場(chǎng)自然狀態(tài)完全分解大概需要45-90天,無(wú)危害成份產(chǎn)生,對(duì)陸地生物及、海洋珊瑚或海洋生物不會(huì)造成危害。
      In the absence of any industrial decomposition machine, it takes about 45-90 days for the pulp molded environmental protection tableware to be completely decomposed in the natural state of the landfill, without harmful components, and will not cause harm to terrestrial organisms, marine corals or marine organisms.
      降解后82%的成份為有機(jī)質(zhì),可用作土地使用的肥料,取材自然,回歸自然。
      After degradation, 82% of the ingredients are organic matter, which can be used as fertilizer for land use. The materials are natural and return to nature.
      五、一次性紙漿餐具可以微波加熱和冰箱冷藏嗎?能達(dá)到多少溫度?
      5、 Can disposable pulp tableware be microwave heated and refrigerated? How much temperature can it reach?
      可降解紙漿餐盒可以微波加熱、烤箱烘烤,且不會(huì)產(chǎn)品有害化學(xué)物質(zhì),溫度可達(dá)220℃。
      The degradable pulp lunch box can be heated by microwave and baked in oven without harmful chemicals. The maximum temperature can reach 220 ℃.
      可支持冰箱冷凍冷藏,冷凍可達(dá)零下18℃。
      It can support refrigeration in the refrigerator, and the freezing can reach minus 18 ℃.
      六、紙漿模塑餐盒符合什么類型產(chǎn)品質(zhì)量檢測(cè)標(biāo)準(zhǔn)?
      6、 What type of product quality inspection standard does the pulp molded lunch box meet?
      生物全降解植物纖維餐盒符合《紙漿模塑餐具》質(zhì)量檢驗(yàn)標(biāo)準(zhǔn)、美國(guó)食品藥品監(jiān)督管理局(FDA)、德國(guó)新食品和飲食用品法(LFGB)、等標(biāo)準(zhǔn)化檢驗(yàn)標(biāo)準(zhǔn)。
      The biodegradable vegetable fiber lunch box meets the national quality inspection standard of pulp molded tableware, the American food and Drug Administration (FDA), the German new food and dietary products act (lfgb), and other international standardized inspection standards.
      七、生物全降解餐盒可以印刷logo嗎?
      7、 Can a biodegradable lunch box be printed with a logo?
      可以印刷logo,印刷產(chǎn)品多為餐盒產(chǎn)品的周圈、底部或頂部,杯子、碗之類產(chǎn)品多印刷在產(chǎn)品外側(cè),需使用曲面印刷。按照印刷設(shè)備分為絲網(wǎng)印刷、移印印刷和激光雷射印刷(噴碼印刷)。
      Logo can be printed. Most of the printed products are the circle, bottom or top of lunch box products. Cups, bowls and other products are mostly printed on the outside of the products, and curved surface printing is required. According to the printing equipment, it is divided into screen printing, pad printing and laser laser printing (inkjet printing).
      印刷類產(chǎn)品會(huì)相應(yīng)提高產(chǎn)品成本。
      Printing products will increase product costs accordingly.
      八、白色可降解餐盒使用的原材料漂白過(guò)嗎?使用什么漂白劑?
      8、 Have the raw materials used in white degradable lunch boxes been bleached? What bleach do you use?
      未漂白過(guò)的植物纖維紙漿因含少量木素和有色雜質(zhì),所以呈黃色,纖維也較硬。半漂漿中含有大量的多縮戊糖,顏色呈淺黃色,俗稱本色。漂白漿的纖維潔白,質(zhì)地純潔而柔軟,但由于經(jīng)過(guò)漂白處理,纖維強(qiáng)度低于未漂漿。
      Unbleached plant fiber pulp is yellow and hard because it contains a small amount of lignin and colored impurities. Semi bleached pulp contains a large amount of pentosan, which is light yellow, commonly known as natural color. The fiber of bleached pulp is white, pure and soft, but the fiber strength is lower than that of unbleached pulp due to bleaching treatment.
