      一次性餐具三招教你區(qū)分好壞
      一次性餐具三招教你區(qū)分好壞
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2021-09-29 14:15:03
      越來(lái)越多飯店運(yùn)用塑料薄膜包裹的餐具,它們看起來(lái)很潔凈、正軌,包裝上還印有“衛(wèi)餐消證號(hào)”、消費(fèi)日期、廠(chǎng)家等信息,但是,它們真的有那麼潔凈嗎?
      More and more restaurants use plastic film-wrapped disinfection tableware. They look clean and on the right track. There are also information such as "Sanitary Dissipation Certificate", "Date of Consumption", "Manufacturer" on the package. But do they really have that kind of cleanliness?
      許多飯店都運(yùn)用這種的餐具,一來(lái),可以處理人手缺乏的成績(jī),二來(lái),餐廳可以從中獲取一筆利潤(rùn)。有效勞生表示,假如不必這種餐具,飯店也可提供收費(fèi)餐具。但是每天那麼多主人,人手顧不過(guò)去,碗筷洗得一定沒(méi)的潔凈。另外,除掉飯店要增添的設(shè)備,以及少量洗潔精、水、電及人工費(fèi),按推銷(xiāo)價(jià)爲(wèi)0.9元,向消費(fèi)者收1.5元餐具費(fèi)來(lái)算,每天用400套的話(huà),飯店多盈利240元。
      Many restaurants use this kind of free disinfection tableware. First, they can deal with the lack of manpower. Second, they can make a profit from it. Effective laborers said that if such tableware is not needed, restaurants can also provide charged tableware. But every day so many owners, hands can not afford to go, dishes and chopsticks must be unprofessional clean. In addition, except for the additional disinfection equipment, as well as a small amount of detergent, water, electricity and labor costs, the hotel will make a profit of up to 240 yuan a day at the sales price of 0.9 yuan and charge consumers 1.5 yuan for tableware.
      三招教你區(qū)分潔凈餐具
      Three ways to teach you how to distinguish clean tableware
      招:看包裝。下面應(yīng)印有消費(fèi)廠(chǎng)家的明白信息,如廠(chǎng)址、電話(huà)等
      First trick: Look at the packaging. The following should be printed with clear information of consumer manufacturers, such as factory address, telephone, etc.
      第二招:細(xì)察看。察看能否注明出廠(chǎng)日期或保質(zhì)期。
      Second trick: Look carefully. See if you can specify the date of departure or shelf life.
      第三招:聞滋味。將餐具翻開(kāi),聞聞?dòng)袩o(wú)刺鼻、發(fā)霉滋味。
      Third trick: Smell. Turn the tableware over and smell whether it smells pungent or mouldy.
      一副合格的餐具該當(dāng)具有以下四個(gè)特性,小同伴們可要看細(xì)心啦!
      A set of qualified tableware should have the following four characteristics, small companions should watch carefully!
      光:有較好的光澤,顏色不發(fā)舊。
      Light: It has a good gloss, and the color is not old.
      潔:外表潔凈無(wú)食物殘?jiān)⒚裹c(diǎn)。
      Clean: Clean appearance without food residue, mildew.
      澀:摸起來(lái)的手感也應(yīng)該是澀的,而不是滑膩感,這標(biāo)明油漬、洗濯?jiǎng)┒急幌吹袅恕?/div>
      Acerbity: The touch should also be astringent, not slippery, which indicates that grease stains and detergents have been washed away.
      干:餐具經(jīng)過(guò)低溫烘干,不會(huì)有水分,假如包裝膜里有水珠,那一定不正常,連水漬都不應(yīng)該有。
      Dry: Disinfection tableware after low temperature sterilization drying, there will be no water, if there are droplets in the packaging film, it must be abnormal, even water stains should not be there.
      綜上所述有安徽鑫科生物環(huán)保有限公司提供,想了解更多一次性餐具知識(shí),歡迎關(guān)注我們的網(wǎng)站:http://m.hydronic.cn謝謝支持!
      To sum up, Anhui Xinke Biological Environmental Protection Co., Ltd. provides more knowledge about disposable tableware. Welcome to our website: http://m.hydronic.cn. Thank you for your support.
