      可降解塑料餐具究竟安不?
      可降解塑料餐具究竟安不?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2021-03-22 17:45:38
      如何選購可降解塑料餐具?
      How to choose degradable plastic tableware?
      1.查看生產(chǎn)廠家名稱、地址、聯(lián)系方式、執(zhí)行標(biāo)準(zhǔn)等(可降解塑料不屬于發(fā)證產(chǎn)品范圍,無生產(chǎn)許可標(biāo)志)。
      1. Check the manufacturer's name, address, contact information, executive standards, etc. (degradable plastics do not belong to the scope of licensed products, no production license mark).
      2.查看產(chǎn)品是一次性使用或重復(fù)使用。若重復(fù)使用一次性產(chǎn)品,可能會(huì)產(chǎn)生一些未知的風(fēng)險(xiǎn)。
      2. Check whether the product is disposable or reusable. If the disposable products are reused, there may be some unknown risks.
      3.查看材質(zhì)??山到馑芰喜馁|(zhì)種類較多,某些材質(zhì)有特殊使用要求,如PBAT材質(zhì)不得用于接觸冷凍食品和冷藏食品,PHB材質(zhì)不得用于接觸含乙醇食品。
      3. Check the material. There are many kinds of degradable plastic materials, and some materials have special use requirements. For example, PBAT material should not be used to contact frozen food and refrigerated food, PHB material should not be used to contact food containing ethanol.
      4.查看使用溫度(是否可微波使用)。可降解塑料一般使用溫度要求小于100℃,大部分不可微波加熱,某些可降解塑料不可冷藏或冷凍(如PBAT材質(zhì))。
      4. Check the use temperature (whether it can be used by microwave). Generally, the use temperature of degradable plastics should be less than 100 ℃, most of them can not be heated by microwave, and some degradable plastics can not be refrigerated or frozen (such as PBAT material).
      5.查看盛裝食品類型。注意是否有特殊說明不可用來盛裝某些特殊類型的食品(如酸性食品、含乙醇食品、油性食品等)。
      5. Check the type of food. Pay attention to whether there are special instructions that can not be used to hold some special types of food (such as acid food, ethanol food, oily food, etc.).
      挑選小竅門
      Tips for choosing
      一看:看顏色和雜質(zhì)黑點(diǎn),盡量選原色無雜質(zhì)的產(chǎn)品;
      A look: look at the color and impurity black spots, try to choose primary color products without impurities;
      二聞:選擇無異味無異臭的產(chǎn)品;
      Second smell: choose products without peculiar smell and odor;
      三摸:選擇觸感光滑,盡量不選觸感粗糙的產(chǎn)品。
      Three touch: choose smooth touch, try not to choose rough touch products.
