玉米淀粉餐具的兩種材質(zhì)你都了解嗎??
玉米淀粉憑借綠色無(wú)污染,使用后可自然降解的特性,受到了大眾的關(guān)注!下面一次性玉米淀粉餐具廠家就給大家普及一下這種餐具的兩種材質(zhì),希望對(duì)大家有所幫助!
Corn starch has attracted public attention because of its green, non-polluting and natural degradation after use. The following disposable corn starch tableware manufacturers to popularize the two materials of this tableware, I hope to help you!
玉米淀粉餐具主要分兩種,看材質(zhì)說(shuō)明,一種是淀粉基,淀粉的主要來(lái)源是玉米,所以有時(shí)也叫玉米淀粉基,其實(shí)是淀粉和傳統(tǒng)石油基PP等的混合塑料,國(guó)外叫生物基。是可以通過(guò)淀粉的生物降解而致使整個(gè)材料物理性能崩潰,但崩潰后的石油基PP還是不可降解的。對(duì)比傳統(tǒng)的餐具是比較環(huán)保,成本也差不多。
Corn starch tableware is mainly divided into two kinds, according to the material description, one is starch base, the main source of starch is corn, so sometimes it is also called corn starch base, in fact, starch and traditional petroleum-based PP mixed plastic, called biological base abroad. The physical properties of the whole material can be collapsed by the biodegradation of starch, but the petroleum-based PP after the collapse is still non-degradable. Compared with traditional tableware, it is more environmentally friendly, and the cost is similar.
另一種是PLA聚乳酸,1噸的聚乳酸是用3噸的玉米淀粉提取轉(zhuǎn)化出來(lái)的,工藝流程復(fù)雜,所以也比較高,這種是完全可降解的。但是純PLA是不耐高溫的,所以市場(chǎng)上的完全降解餐具大多是改性PLA做的,也是添加完全生物降解的石油基PBAT等其他材料的。如果宣傳完全降解,生物基部分和石油基部分都必須是完全可降解的。
The other is PLA polylactic acid. One ton of PLA is extracted and transformed from 3 tons of corn starch. The process is complex, so the price is relatively high. This kind of PLA is completely degradable. But pure PLA is not resistant to high temperature, so most of the fully degradable tableware on the market is made of modified PLA, which is also added with other materials such as petroleum-based PBAT which is completely biodegradable. If the propaganda is completely degradable, both the bio-based and petroleum-based parts must be completely degradable.
嚴(yán)格意義上說(shuō),淀粉基混合PP那種從整體看不能稱(chēng)為可降解,或者部分可降解,因?yàn)檎w放在堆肥環(huán)境中式?jīng)]法降解的,只有分離出來(lái)才可以。歐洲已經(jīng)不用降解,完全降解來(lái)描述材質(zhì),用可堆肥來(lái)說(shuō)明,因?yàn)榭啥逊蕦?duì)降解的時(shí)間,降解后的顆粒大小,降解后成分對(duì)植物生長(zhǎng)的影響都進(jìn)行限定,來(lái)保證材質(zhì)的性。
Strictly speaking, the starch-based blended PP can not be called degradable or partially degradable as a whole, because the whole can not be degraded in composting environment, only separated. In Europe, there is no need to degrade completely to describe the material. Compost can be used to explain it. Because compost can limit the time of degradation, the size of degraded particles and the effect of degraded components on plant growth to ensure the safety of material.
感謝您的閱讀與觀看,本文的精彩內(nèi)容來(lái)自:一次性玉米淀粉餐具,我們會(huì)有更多的精彩內(nèi)容繼續(xù)為您呈現(xiàn),詳情請(qǐng)點(diǎn)擊:http://m.hydronic.cn
Thank you for your reading and watching. The wonderful content of this article comes from: disposable corn starch tableware. We will continue to show you more wonderful content. For more details, please click: http://m.hydronic.cn.
- 上一個(gè): 聚丙烯餐具有什么優(yōu)點(diǎn)?
- 下一個(gè): 一次性生物降解餐具的普及面臨哪些難題?
