      聚丙烯餐具有什么優(yōu)點?
      聚丙烯餐具有什么優(yōu)點?
      網(wǎng)址:http://m.hydronic.cn 手機頁面二維碼 2019-08-06 15:46:55
      聚丙烯是一種塑料材料,現(xiàn)在被廣泛用于餐具的制作,那么你知道聚丙烯餐具的優(yōu)點嗎?下面就讓一次性餐具廠家為我們詳細的介紹一下,希望對大家有所幫助!
      Polypropylene is a kind of plastic material, which is widely used in the production of tableware. Do you know the advantages of polypropylene tableware? Now let the disposable tableware manufacturers give us a detailed introduction, hoping to help you all!
      聚丙烯(PP塑料)是繼尼龍之后發(fā)展的又一優(yōu)良樹脂品種,它是一種高密度、無側鏈、高結晶必的線性聚合物,具有優(yōu)良的綜合性能。
      Polypropylene (PP plastic) is another excellent resin after nylon. It is a linear polymer with high density, no side chain and high crystallinity. It has excellent comprehensive properties.
      未著色時呈白色半透明,蠟狀;比聚乙烯輕。透明度也較聚乙烯好,比聚乙烯剛硬。物料性能 :密度小,強度剛度,硬度耐熱性均優(yōu)于低壓聚乙烯,可在100度左右使用。
      It is white translucent and waxy when not colored; lighter than polyethylene. Transparency is also better than polyethylene, rigid than polyethylene. Material properties: low density, strength and stiffness, hardness and heat resistance are better than low pressure polyethylene, can be used at about 100 degrees.
      具有良好的電性能和高頻絕緣性不受濕度影響,但低溫時變脆,不耐磨易老化。適于制作一般機械零件,耐腐蝕零件和絕緣零件。
      It has good electrical performance and high frequency insulation, which is not affected by humidity, but becomes brittle at low temperature, wear-resistant and aging-prone. Suitable for making general mechanical parts, corrosion resistant parts and insulation parts.
      熔化溫度: 220~275℃,注意不要超過275℃。常見制品:盆、桶、家具、薄膜、編織袋、瓶蓋、汽車保險杠等。 pp材料即聚丙烯,是的,它的密度是密度0.851~0.935克/立方厘米 ,主要可應用于微波爐餐具、盆、塑料桶、保溫瓶外殼、編織袋等。
      Melting temperature: 220 ~ 275 C. Be careful not to exceed 275 C. Common products: pots, barrels, furniture, film, woven bags, bottle caps, car bumpers, etc. PP material, namely polypropylene, is safe and non-toxic. Its density is 0.851-0.935 g/cubic centimeter. It can be mainly used in microwave oven tableware, basin, plastic bucket, thermos bottle shell, woven bag and so on.
      它有化學穩(wěn)定性高、衛(wèi)生性能好、耐熱性高等優(yōu)點,微波爐餐具可選用標明PP字樣的塑料制品,可放心使用。
      It has the advantages of high chemical stability, good hygienic performance and high heat resistance. Microwave oven tableware can be used with plastic products marked PP, which can be safely used.
      以上內容就是今天的精彩內容了,感謝大家的閱讀。更多的詳細資訊,敬請關注:一次性餐具!如果您對我們還滿意,請轉告身邊的朋友,如果您覺得我們的服務欠佳,歡迎大家提出寶貴的意見,感謝大家的支持!我們的網(wǎng)址:http://m.hydronic.cn
      The above is today's wonderful content. Thank you for your reading. More detailed information, please pay attention to: disposable tableware! If you are satisfied with us, please tell your friends. If you feel that our service is not good, you are welcome to make valuable comments and thank you for your support. Our website: http://m.hydronic.cn
