      怎樣合理使用一次性玉米淀粉餐具?
      怎樣合理使用一次性玉米淀粉餐具?
      網(wǎng)址:http://m.hydronic.cn 手機頁面二維碼 2024-03-25 18:45:58
      1、加熱時取下一次性玉米淀粉餐具盒蓋:
      1. Remove the disposable corn starch tableware box cover when heating:
      有些微波爐餐盒,盒體以5號PP制造,但盒蓋卻以4號PE制造,而PE是不能抵受高溫。所以放入微波爐前,記得把蓋子取下。
      Some microwave lunch boxes have a body made of No. 5 PP, but the lid is made of No. 4 PE, which cannot withstand high temperatures. So before putting it into the microwave, remember to remove the lid.
      2、及時更換:
      2. Timely replacement:
      餐盒的使用年限一般為3-5年,但當其出現(xiàn)變色、變脆、變黃的情形,應(yīng)及時更換。
      The service life of a lunch box is generally 3-5 years, but when it changes color, becomes brittle, or turns yellow, it should be replaced in a timely manner.
      3、玉米淀粉餐具不建議反復(fù)使用:
      3. Corn starch tableware is not recommended for repeated use:
      現(xiàn)在很多外賣盒,看著質(zhì)量不錯,標注的也是比較的玉米淀粉材質(zhì),有些人就忍不住洗干凈囤在家里重復(fù)使用。但其實這是不對的。
      Nowadays, many takeout boxes look good in quality and are labeled with relatively safe corn starch material. Some people can't help but wash them clean and store them at home for reuse. But actually, this is not right.
      出于成本控制等原因,通常一次性玉米淀粉餐具其制作出來的目的,就是盛裝一次、溫度較高的、可能有油的食物,在這個條件下使用,是的。但如果使用次數(shù)較多,就會破壞其穩(wěn)定性,其中的有害物質(zhì)析出,長期下來可能會影響身體~
      Due to cost control and other reasons, disposable corn starch tableware is usually made for the purpose of containing once, high temperature, and potentially oily food. It is safe to use under these conditions. But if used frequently, it will damage its stability, and harmful substances may precipitate, which may affect the body in the long run~
      4、不盛放會加速餐盒老化的食物:
      4. Not storing food that can accelerate the aging of the lunch box:
      如果一次性餐具內(nèi)長時間存放酒精、碳酸飲料、醋等酸性物質(zhì),加快老化。所以,如果您家有自制的醋泡花生、楊梅酒等,記得不要放在一次性餐具里,不妨換成玻璃器皿儲存。
      If alcohol, carbonated drinks, vinegar, and other acidic substances are stored in disposable tableware for a long time, it will accelerate aging. So, if you have homemade vinegar soaked peanuts, yangmei wine, etc. at home, remember not to put them in disposable tableware. It's better to replace them with glassware for storage.
      5、清潔到位:
      5. Cleaning in place:
      有些人使用一次性玉米淀粉餐具時,為了保持密封性,會在蓋子上裝上密封圈。但食物殘渣滲入到密封圈里,就成為了霉菌的“福地”。
      Some people, when using disposable cornstarch tableware, install a sealing ring on the lid to maintain sealing. But when food residue seeps into the sealing ring, it becomes a blessing for mold.
      建議每次清洗時,把密封圈及其溝槽清洗干凈,晾干后,再裝回蓋子上。
      It is recommended to clean the sealing ring and its groove thoroughly during each cleaning, air dry them, and then reinstall them on the cover.
      本文由一次性玉米淀粉餐具提供技術(shù)支持,更多的詳細精彩內(nèi)容請點擊我們的網(wǎng)站http://m.hydronic.cn我們將會全心全意為您提供滿意的服務(wù)。
      This article provides technical support for disposable corn starch tableware. For more detailed and exciting content, please click on our website http://m.hydronic.cn We will wholeheartedly provide you with satisfactory service.
