      生物類可降解一次性餐具到底是哪些餐具呢?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2024-03-16 21:53:54
      因?yàn)榕菽淮涡圆秃胁荒透邷兀抑谱鬟^程對環(huán)境造成破壞,已被淘汰,而且長期使用不合格的一次性餐盒會對身體帶來不良影響。
      Because the foam disposable lunch box is not resistant to high temperature, and the production process has caused damage to the environment, it has been eliminated, and long-term use of unqualified disposable lunch boxes will have adverse effects on the body.
      現(xiàn)在都采用環(huán)保餐具,環(huán)保衛(wèi)生,,能減少環(huán)境污染。嘉美公司生產(chǎn)的環(huán)保餐具是生物降解類一次性餐具,下面來了解一下生物降解類一次性餐具。
      Nowadays, environmentally friendly tableware is used, which is environmentally friendly, hygienic, safe and non-toxic, and can reduce environmental pollution. The environmentally friendly tableware produced by Jiamei Company is biodegradable disposable tableware. Let's take a look at biodegradable disposable tableware.
      生物類可降解一次性餐具是一種比較的環(huán)保產(chǎn)品。
      Biodegradable disposable tableware is a relatively advanced environmentally friendly product.
      它以淀粉為主要原料,加入一年生長期植物纖維粉和特殊的添加劑,經(jīng)過化學(xué)和物理方法處理制成生物全降解快餐盒。由于淀粉是一種可生物降解天然高分子,在微生物的作用下分解為葡萄糖,分解為水和二氧化碳。
      It uses starch as the main raw material, adds one-year plant fiber powder and special additives, and is processed by chemical and physical methods to make a biodegradable fast food box. Due to starch being a biodegradable natural polymer, it decomposes into glucose under the action of microorganisms and ultimately into water and carbon dioxide.
      此外,與其共混的材料也是全降解材料,因此可以說它對環(huán)境沒有任何影響。
      In addition, the material it blends with is also a fully biodegradable material, so it can be said that it has no impact on the environment.
      生產(chǎn)原料淀粉的主要來源,可以是玉米、土豆、紅薯、木薯等一年生長期植物。自然,生物全降解生產(chǎn)原料大部分是糧食作物,對環(huán)境無任何污染可完全代替泡沫餐盒。
      The main sources of starch production raw materials can be plants with a one-year growth period, such as corn, potatoes, sweet potatoes, cassava, etc. Naturally, most of the biodegradable production materials are food crops, which can completely replace the foam lunch box without any pollution to the environment.
      標(biāo)準(zhǔn)報(bào)批稿的有關(guān)資料顯示,《一次性可降解餐飲具通用技術(shù)條件》是在《塑料一次性餐飲具通用技術(shù)要求》標(biāo)準(zhǔn)的基礎(chǔ)上修訂的??山到?,是一次性餐飲具的趨勢,為什么這項(xiàng)標(biāo)準(zhǔn)不是從頭做起?全國塑料制品標(biāo)準(zhǔn)化技術(shù)委員會秘書長翁云宣解釋說,本標(biāo)準(zhǔn)為GB/T 18006的系列標(biāo)準(zhǔn)的一部分,內(nèi)容上主要部分代替GB/T 18006.1-2009《塑料一次性餐飲具通用技術(shù)要求》中的可降解餐飲具相關(guān)內(nèi)容,原2009版中的非降解一次性餐飲具仍然執(zhí)行。
      The relevant information of the standard approval draft shows that the General Technical Conditions for Disposable Degradable Catering Utensils are revised based on the national standard General Technical Requirements for Plastic Disposable Catering Utensils. Biodegradable is the trend for disposable tableware, why isn't this standard starting from scratch? Weng Yunxuan, Secretary General of the National Technical Committee for Standardization of Plastic Products, explained that this standard is part of the series of GB/T 18006 standards, and the content mainly replaces the relevant content of degradable tableware in GB/T 18006.1-2009 "General Technical Requirements for Disposable Plastic Tableware". The non degradable disposable tableware in the original 2009 version is still implemented.
