熱塑改性淀粉基生物降解塑料也可以做餐具?
然淀粉為天然的多羥基化合物,分子之間存在大量的氫鍵,這種分子間強(qiáng)的相互作用使其分解溫度低于熔融溫度,導(dǎo)致天然淀粉沒有可加工性。
Natural starch is a natural polyhydroxy compound with a large number of hydrogen bonds between molecules. This strong intermolecular interaction causes its decomposition temperature to be lower than the melting temperature, resulting in the lack of processability of natural starch.
在淀粉中加入小分子增塑劑,經(jīng)過高溫、高壓和剪切作用能夠使淀粉具有可加工性能,使天然淀粉變成熱塑性淀粉。
Adding small molecule plasticizers to starch can enhance its processability through high temperature, high pressure, and shear, transforming natural starch into thermoplastic starch.
制作熱塑性淀粉的常用方法是將淀粉、甘油和水充分混合分散,在一定溫度下攪拌一定時間,獲得凝膠狀態(tài)的熱塑性淀粉。進(jìn)一步添加增強(qiáng)劑,對熱塑性淀粉材料的性能進(jìn)行改善。
The common method for preparing thermoplastic starch is to fully mix and disperse starch, glycerin and water, and stir at a certain temperature for a certain time to obtain thermoplastic starch in gel state. Further addition of reinforcing agents can improve the performance of thermoplastic starch materials.
為獲得容易被生物降解、可取代石油衍生物的包裝材料,研究者以不同植物來源的淀粉為原料,添加一定量的甘油,采用流延法制備了熱塑性淀粉基薄膜。熱塑改性后的淀粉具有大的淀粉結(jié)構(gòu)域、良好的熱穩(wěn)定性能和抗吸水性,但膜的剛度低。為改善對熱塑性淀粉膜的性能,他們在熱塑性淀粉基質(zhì)中加入纖維素納米粒子,獲得的膜在剛性、熱穩(wěn)定性、耐濕性等方面均有所提高。
In order to obtain packaging materials tha
t are easily biodegradable and can replace petroleum derivatives, researchers used starch from different plant sources as raw materials, added a certain amount of glycerol, and prepared thermoplastic starch based films using a tape casting method. The thermoplastic modified starch has a large starch structure domain, good thermal stability, and water resistance, but the membrane stiffness is low. To improve the performance of thermoplastic starch films, they added cellulose nanoparticles to the thermoplastic starch matrix, resulting in improved film rigidity, thermal stability, and moisture resistance.
t are easily biodegradable and can replace petroleum derivatives, researchers used starch from different plant sources as raw materials, added a certain amount of glycerol, and prepared thermoplastic starch based films using a tape casting method. The thermoplastic modified starch has a large starch structure domain, good thermal stability, and water resistance, but the membrane stiffness is low. To improve the performance of thermoplastic starch films, they added cellulose nanoparticles to the thermoplastic starch matrix, resulting in improved film rigidity, thermal stability, and moisture resistance.利用甘油增塑改性玉米淀粉,然后將熱塑改性淀粉和蠟質(zhì)淀粉、纖維素納米晶體復(fù)合,制備熱塑性玉米淀粉基生物納米復(fù)合材料。經(jīng)復(fù)合后,材料的力學(xué)性能和透氧性提高,熱穩(wěn)定性降低。
Using glycerol to plasticize and modify corn starch, thermoplastic modified starch is then compounded with waxy starch and cellulose nanocrystals to prepare thermoplastic corn starch based biocomposites. After composite, the mechanical properties and oxygen permeability of the material are improved, while the thermal stability is reduced.
從小麥秸稈中獲取納米纖維素, 將淀粉、甘油、納米纖維素混合并持續(xù)加熱攪拌, 獲得黏稠的熱塑性淀粉基復(fù)合物,并用流延法制作薄膜。相比于未復(fù)合納米纖維素的薄膜,隨著納米纖維素含量的增加,復(fù)合薄膜的力學(xué)性能先增強(qiáng)后降低,這與纖維的團(tuán)聚有關(guān)。
Obtain nanocellulose from wheat straw, mix starch, glycerol, and nanocellulose and continuously heat and stir to obtain a viscous thermoplastic starch based composite, and prepare a thin film using tape casting method. Compared to the film without composite nanocellulose, with the increase of nanocellulose content, the mechanical properties of the composite film first increase and then decrease, which is related to the aggregation of fibers.
將工業(yè)玉米淀粉利用甘油熱塑改性后,分別利用從劍麻、大麻中獲得的纖維增強(qiáng)熱塑玉米淀粉制備復(fù)合材料。發(fā)現(xiàn)劍麻和大麻纖維的摻入使熱塑性玉米淀粉的玻璃化轉(zhuǎn)變溫度(Tg ) 升高,剛性增強(qiáng),力學(xué)性能無顯著改變。此外,向復(fù)合材料中添加天然乳膠,進(jìn)行增塑改性,改性后復(fù)合材料的吸水性降低,材料的熱穩(wěn)定性和力學(xué)性能無明顯影響。
After thermoplastic modification of industrial corn starch with glycerol, composite materials were prepared using fiber reinforced thermoplastic corn starch obtained from sisal and hemp, respectively. It was found that the addition of sisal and hemp fibers increased the glass transition temperature (Tg) of thermoplastic corn starch, enhanced its rigidity, and did not significantly change its mechanical properties. In addition, adding natural latex to the composite material for plasticization modification resulted in a decrease in water absorption of the composite material, with no significant impact on its thermal stability and mechanical properties.
以D-山梨醇作為淀粉的塑化劑, 在加熱剪切的條件下對淀粉進(jìn)行塑化改性。加入纖維素納米纖維(CNF)對熱塑改性的淀粉進(jìn)行增強(qiáng)改性,發(fā)現(xiàn) CNF 可改善熱塑性淀粉的力學(xué)性能和濕敏性。CNF在擠出過程中聚集,而螺桿擠出技術(shù)需要分散更均勻的復(fù)合物才能得到均勻的材料。
Using D-sorbitol as a plasticizer for starch, the starch was plasticized and modified under heating and shearing conditions. Adding cellulose nanofibers (CNF) to enhance and modify thermoplastic modified starch, it was found that CNF can improve the mechanical properties and moisture sensitivity of thermoplastic starch. CNF aggregates during the extrusion process, while screw extrusion technology requires more evenly dispersed composites to obtain uniform materials.
熱塑改性的淀粉基生物降解塑料克服了天然淀粉不具加工性的缺陷,但制備的產(chǎn)品存在韌性差、 耐壓不高、易碎,特別是遇水后產(chǎn)品易軟化,使產(chǎn)品的使用性能受到影響。仍需進(jìn)一步調(diào)整改進(jìn)產(chǎn)品配方和工藝,使產(chǎn)品具有更好的使用性能。
Thermoplastic modified starch based biodegradable plastics overcome the shortcomings of natural starch's non processability, but the prepared products have poor toughness, low pressure resistance, and are fragile, especially when exposed to water, which can easily soften the products and affect their performance. Further adjustments and improvements are still needed to improve the product formula and process, so that the product has better usability.
感謝您的閱讀,此文的文章來源:玉米淀粉顆粒更多的內(nèi)容和問題請點擊:http://m.hydronic.cn我們會繼續(xù)努力的為您提供服務(wù),感謝您的支持!
Thank you for reading. The source of this article is corn starch granules. For more information and questions, please click on: http://m.hydronic.cn We will continue to work hard to provide you with services. Thank you for your support!
