玉米淀粉餐具的原料性質(zhì)有哪些你清楚嗎?
可降解的一次性玉米淀粉餐具類共聚物,在任何一小部分,有更好的空間結(jié)構(gòu)如下:可降解物質(zhì)退化時(shí),整個(gè)物質(zhì)分為單一幾何的碎片,和分子量的幾何是大大減少,這是容易吸收的性質(zhì)。實(shí)際操作過程中的重要解決方案:
Biodegradable disposable corn starch tableware copolymers have a better spatial structure in any small part as follows: when degradable substances degrade, the entire substance is divided into single geometric fragments, and the geometric molecular weight is greatly reduced, which is a property that is easy to absorb. Important solutions in practical operation:
一是降解材料和整個(gè)材料之間的力。
One is the force between the degradation material and the entire material.
由于化學(xué)變化不是共價(jià)鍵合力或離子鍵合力,牛頓引力遠(yuǎn)遠(yuǎn)不能滿足產(chǎn)品強(qiáng)度的要求。因此,使其在微觀空間下具有盡可能多的分子間作用力的問題得到了解決。這是形成可降解共聚物的更初難點(diǎn)所在。
Because the chemical change is not the resultant force of covalent bond or ionic bond, Newton's gravity is far from meeting the requirements of product strength. Therefore, the problem of having as much intermolecular force as possible in the micro space has been solved. This is the initial difficulty in forming degradable copolymers.
二是解決降解物質(zhì)與整體物質(zhì)的不整合問題。
The second is to solve the problem of unconformity between the degraded material and the whole material.
以淀粉和PE為例,前者是強(qiáng)極性分子,后者是非極性分子,兩者并不協(xié)調(diào)、相容,而是相互仇恨,分子間力的形式單一,力小。解決辦法是在兩者之間加入交聯(lián)劑、偶聯(lián)劑、表面活性劑等物質(zhì)。這是形成可降解共聚物的第二個(gè)難點(diǎn)。
Taking starch and PE as examples, the former is a strongly polar molecule, while the latter is a non-polar molecule. The two are not coordinated or compatible, but rather hate each other. The form of intermolecular force is single and the force is small. The solution is to add substances such as crosslinking agents, coupling agents, and surfactants between the two. This is the second challenge in forming degradable copolymers.
當(dāng)然,在可支配的實(shí)際批量生產(chǎn)玉米淀粉餐具,還輔以具體的發(fā)起者,self-oxidant等等,合成樹脂系統(tǒng)結(jié)構(gòu)的光,熱,氧和微生物化學(xué)作用,獨(dú)立基礎(chǔ)的連鎖反應(yīng),因此其分子量是大大減少實(shí)現(xiàn)深度降解。毫無疑問,傳統(tǒng)的樹脂,如塑料,在新的組合中不是單一的連續(xù)結(jié)構(gòu)。整個(gè)新的共混物應(yīng)該是一個(gè)幾乎處處均勻、處處幾乎連續(xù)的多相粒子體。此外,每個(gè)組成部分的粒子都應(yīng)該是小的,以便接近一個(gè)良好的空間。
Of course, in the actual batch production of corn starch tableware that can be controlled, it is also supplemented by specific initiators, self oxidants, and other factors. The light, heat, oxygen, and microbial chemical reactions of the synthetic resin system structure are independent and basic chain reactions, so its molecular weight is greatly reduced to achieve deep degradation. Undoubtedly, traditional resins, such as plastics, are not a single continuous structure in new combinations. The whole new blend should be a multiphase particle body which is almost uniform and continuous in almost everywhere. In addition, the particles of each component should be small in order to approach a good space.
一次性玉米淀粉餐具具有節(jié)約木材、保護(hù)森林資源和保護(hù)自然環(huán)境的重要意義,可以指導(dǎo)原塑料制品行業(yè)在其堅(jiān)實(shí)的生產(chǎn)基礎(chǔ)上生產(chǎn)新產(chǎn)品。
Disposable corn starch tableware has important significance in saving wood, protecting forest resources, and protecting the natural environment. It can guide the original plastic product industry to produce new products on its solid production foundation.
感謝您的閱讀,此文的文章來源:一次性環(huán)保餐具更多的內(nèi)容和問題請點(diǎn)擊: http://m.hydronic.cn我們會(huì)繼續(xù)努力的為您提供服務(wù),感謝您的支持!
Thank you for reading. The source of this article is disposable environmentally friendly tableware. For more information and questions, please click on: http://m.hydronic.cn We will continue to work hard to provide you with services. Thank you for your support!
- 上一個(gè): 一次性玉米淀粉餐具比市面的餐盒更低!
- 下一個(gè): 可降解餐盒怎么符合外賣商家的需求?
