      玉米淀粉餐盒為什么會(huì)成為更多的餐飲選擇!
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2023-03-20 19:40:13
      以玉米淀粉基為原料的一次性環(huán)保餐盒,、無(wú)害、無(wú)污染,提升外賣(mài)打包檔次、使用方便不易撒漏。使用玉米淀粉基環(huán)保餐盒可大量節(jié)省森林資源。玉米淀粉基環(huán)保餐盒在一定程度上可以替代塑料制品餐盒,減少對(duì)環(huán)境的白色污染。是餐飲市場(chǎng)上普遍使用卻飽受爭(zhēng)議的“餐具”的理想替代品。
      The disposable environment-friendly lunch box made from corn starch is non-toxic, harmless, and pollution-free, improving the packaging level of takeaway food, making it easy to use and not easy to spill. Using corn starch based environmentally friendly lunch boxes can greatly save forest resources. Corn starch based environmentally friendly lunch boxes can to some extent replace plastic lunch boxes, reducing white pollution to the environment. It is an ideal substitute for the widely used but controversial "sterilized tableware" in the catering market.
      玉米淀粉基是環(huán)保可降解產(chǎn)品,真正做到無(wú)污染,節(jié)約資源??山到庥衩椎矸鄄馁|(zhì),主要是從玉米中所提取的淀粉原料,是一種自然環(huán)境中通過(guò)微生物和酵素,可自然生物降解的環(huán)保材料,環(huán)保無(wú)異味,使用更。產(chǎn)品埋入泥土中,在適宜的溫度下,90天后可降解形成二氧化碳和水,對(duì)土壤和空氣不造成污染,可以節(jié)省大量的石油資源和森林資源。
      Corn starch based products are environmentally friendly and biodegradable, truly pollution-free and resource saving. Degradable corn starch material, mainly a starch raw material extracted from corn, is an environmentally friendly material that can be naturally biodegradable through microorganisms and enzymes in the natural environment, which is environmentally friendly and odorless, making it safer to use. The product is buried in the soil and can be degraded to form carbon dioxide and water after 90 days at a suitable temperature. It does not cause pollution to the soil and air, and can save a lot of oil and forest resources.
      餐盒具備耐熱、耐寒,同時(shí)兼顧抗擠壓、耐水、耐油、防滲透等特點(diǎn)。經(jīng)過(guò)科學(xué)試驗(yàn),餐盒具有良好的耐高溫和耐低溫性(-18,120℃),在冰箱中可冷凍、冷藏、保鮮,可在微波爐加熱等,多種使用方式均不產(chǎn)生有害物質(zhì)。
      The lunch box has the characteristics of heat and cold resistance, as well as anti extrusion, water resistance, oil resistance, and penetration resistance. After scientific experiments, the lunch box has good resistance to high and low temperatures (- 18120 ℃). It can be frozen, refrigerated, and kept fresh in a refrigerator, and can be heated in a microwave oven. Many methods of use do not produce harmful substances.
      玉米淀粉基餐具是目前市場(chǎng)上比較常見(jiàn)的可降解餐盒,淀粉的主要來(lái)源是玉米,所以有時(shí)叫玉米淀粉基,但這類(lèi)餐盒其實(shí)是淀粉和傳統(tǒng)石油基PP等的混合塑料,國(guó)外叫生物基。玉米淀粉基餐具是通過(guò)淀粉的生物降解而致使整個(gè)材料物理性能崩潰,但崩潰后的石油基PP還是不可降解的,降解率根據(jù)餐盒成分可達(dá)40%-80%,所以只能算是可降解餐盒,而不能算是全降解。因此玉米淀粉基餐具只能在一定程度上替代塑料制品,是目前市場(chǎng)上飽受爭(zhēng)議的塑料餐具的替代品。
      Corn starch based tableware is a relatively common biodegradable lunch box in the current market. The main source of starch is corn, so it is sometimes called corn starch based. However, this type of lunch box is actually a mixture of starch and traditional petroleum based PP plastics, which is called biological based abroad. Corn starch based tableware is biodegradable through starch, resulting in the collapse of the physical properties of the entire material. However, the collapsed petroleum based PP is still non degradable, and the degradation rate can reach 40% to 80% based on the composition of the lunch box, so it can only be considered a degradable lunch box, not a fully degradable lunch box. Therefore, corn starch based tableware can only replace plastic products to a certain extent, and is a controversial alternative to plastic tableware in the current market.
      本文由一次性環(huán)保餐具整理發(fā)布,您是不是對(duì)這些內(nèi)容有所了解了呢?更多的內(nèi)容請(qǐng)點(diǎn)擊:http://m.hydronic.cn我們會(huì)有更多精彩內(nèi)容等你查看。
      This article is published by Disposable Environmental Protection Tableware, do you have any understanding of these contents? For more information, please click: http://m.hydronic.cn We will have more exciting content waiting for you to check.
