      有哪些可降解材料可以代替塑料?
      有哪些可降解材料可以代替塑料?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2023-02-25 10:46:15
      環(huán)保的話題一直熱度不減,你知道有哪些可降解材料可以代替塑料嗎?下面可降解顆粒生產(chǎn)廠家為你分析:
      The topic of environmental protection has always been hot. Do you know what biodegradable materials can replace plastics? The following manufacturers of degradable particles will analyze for you:
      可降解材料,是指在一段時(shí)間內(nèi),可在太陽光、溫度、水、化合物、真菌細(xì)菌等微生物,昆蟲,機(jī)械力等自然環(huán)境條件下,被分解為二氧化碳和水等元素的材料。目前,市場(chǎng)上常見的有三類環(huán)??山到獠牧?。
      Degradable materials refer to materials that can be decomposed into carbon dioxide, water and other elements under natural environmental conditions such as sunlight, temperature, water, compounds, fungi and bacteria, insects, mechanical forces and so on. At present, there are three types of environmentally friendly degradable materials in the market.
      一、聚乳酸
      1、 Polylactic acid
      聚乳酸又稱聚丙交酯,是以微生物發(fā)酵產(chǎn)物乳酸為單體化學(xué)合成的。使用后可自動(dòng)降解,不會(huì)污染環(huán)境。
      Poly (lactic acid), also known as polylactide, is chemically synthesized with lactic acid, a product of microbial fermentation, as a monomer. It can be degraded automatically after use and will not pollute the environment.
      二、淀粉塑料
      2、 Starch plastic
      淀粉塑料,指在PP等塑料中添加一定量玉米淀粉、木薯粉、木粉、竹粉等,達(dá)到環(huán)??山到獾哪康?。含淀粉90%以上的淀粉塑料,添加的其他組份也是能降解的。
      Starch plastic refers to adding a certain amount of corn starch, cassava powder, wood powder, bamboo powder, etc. to PP and other plastics to achieve the purpose of environmental protection and degradability. Starch plastics containing more than 90% starch can also be degraded by other components added.
      三、光降解塑料
      3、 Photodegradable plastics
      光降解塑料是指在光的作用下能發(fā)生降解的塑料,通過化學(xué)合成或添加光敏劑獲得。
      Photodegradable plastic refers to the plastic that can degrade under the action of light, which is obtained by chemical synthesis or adding photosensitizer.
      針對(duì)有哪些可降解材料可以代替塑料的問題,我們已經(jīng)做了解答,希望能幫助到你,更多事項(xiàng)就來我們網(wǎng)站http://m.hydronic.cn咨詢吧!
      We have answered the question about which biodegradable materials can replace plastics. We hope it can help you. For more information, please visit our website http://m.hydronic.cn Ask!
