可降解餐盒的原理以及主要成分優(yōu)勢(shì)
可降解餐盒一般是指由可降解塑料可降解紙漿可降解小分子材料制作而成的食物容器,目前使用較多的材料有:PLA(聚乳酸)植物纖維(小麥秸稈漿甘蔗漿竹漿)玉米淀粉基等材質(zhì)。
The degradable lunch box generally refers to the food container made of degradable plastic degradable pulp degradable small molecular materials. At present, the most used materials are: PLA (polylactic acid) plant fiber (wheat straw pulp, sugarcane pulp, bamboo pulp) corn starch base and other materials.
可降解塑料降解不徹底,仍然會(huì)造成污染。一些可降解塑料的成分降解或被微生物吞噬后,剩下的是“骨架”。這些塑料殘留物雖然不像不可降解的塑料那樣以大塊的形式存在,僅僅是變成為小顆粒狀存在于自然界,對(duì)環(huán)境對(duì)土壤仍有影響。
Degradable plastics can still cause pollution due to incomplete degradation. After the components of some degradable plastics are degraded or swallowed by microorganisms, the rest is "skeleton". Although these plastic residues do not exist in the form of large blocks like non-degradable plastics, they only become small particles and exist in nature, which still have an impact on the environment and soil.
可降解顆粒廠家提醒,一次性可降解紙漿模塑餐盒主要成分和優(yōu)勢(shì):
The degradable particle manufacturer reminded that the main components and advantages of disposable degradable pulp molded lunch box:
(1)原料為廢紙漿或可再生的小麥蘆葦?shù)静葜褡痈收嶙貦暗冉斩捓w維,來(lái)源廣泛,低廉,完全不使用木材。
(1) The raw materials are waste pulp or renewable straw fibers such as wheat, reed, rice straw, bamboo, sugarcane and palm, which are widely sourced and cheap, and do not use wood at all.
(2)生產(chǎn)過程無(wú)廢水產(chǎn)生,無(wú)外排。
(2) There is no waste water generated or discharged during the production process.
(3)產(chǎn)品防水防油。
(3) The product is waterproof and oil-proof.
(4)使用過程中可冷凍冷藏,可微波爐加熱可220度烘烤。
(4) It can be frozen and refrigerated during use, and can be heated by microwave oven and baked at 220 degrees.
(5)產(chǎn)品可以在自然狀態(tài)下45-90天內(nèi)完全降解,可家庭堆肥,降解后主要成分是有機(jī)質(zhì),不會(huì)產(chǎn)生任何垃圾殘留和污染。
(5) The product can be completely degraded in 45-90 days under natural conditions, and can be composted at home. After degradation, the main component is organic matter, without any garbage residue and pollution.
(6)作為包裝容器具有緩沖抗壓防震等特點(diǎn),可以有效保護(hù)被包裝的產(chǎn)品。
(6) As a packaging container, it has the characteristics of cushioning, compression resistance and shock resistance, which can effectively protect the packaged products.
(7)包裝電子產(chǎn)品不會(huì)產(chǎn)生靜電。
(7) Packaging electronic products will not generate static electricity.
不同一次性餐盒需要的原料配比也不一樣,一般廠家會(huì)出具產(chǎn)品質(zhì)量檢測(cè)報(bào)告。您對(duì)此有需求或者疑惑歡迎來(lái)我們的網(wǎng)站http://m.hydronic.cn咨詢了解!
The proportion of raw materials required by different disposable lunch boxes is also different. Generally, the manufacturer will issue a product quality test report. Welcome to our website if you have any needs or doubts http://m.hydronic.cn Consult and understand!
- 上一個(gè): 凍融處理對(duì)玉米淀粉凝膠和顆粒的影響
- 下一個(gè): 玉米淀粉基環(huán)保餐盒,用它可以放心!
