大環(huán)境之下的環(huán)保餐具有怎樣的優(yōu)勢表現(xiàn)?
你知多少呢?現(xiàn)在的消費(fèi)者都喜歡使用一次性環(huán)保餐具,所以現(xiàn)在的廠家們就開始有了構(gòu)思,大量生產(chǎn)一次性環(huán)保餐具。受廣大消費(fèi)商家購買。但是環(huán)保餐具雖然方便,也對人體沒有害處,但是會(huì)為社會(huì)制造了很多垃圾。人們的隨地扔垃圾的習(xí)慣就越來越惡劣了。畢竟環(huán)保餐具的好處還是多于壞處的。
How much do you know? Now consumers like to use disposable environment-friendly tableware, so now manufacturers have begun to have ideas and produce disposable environment-friendly tableware in large quantities. It is widely purchased by consumers. But although the environmental protection tableware is convenient and harmless to the human body, it will create a lot of garbage for the society. People's habit of littering is getting worse and worse. After all, the advantages of environment-friendly tableware outweigh the disadvantages.
環(huán)保餐具是所用材料對人體無害,生產(chǎn)過程不對環(huán)境造成污染,產(chǎn)品質(zhì)量完全符合食品衛(wèi)生要求,產(chǎn)品用完后具有易回收、易處置或易消納等特點(diǎn)的食品容器。PP是衛(wèi)生,無害,且回收價(jià)值高。跟發(fā)泡不同的是發(fā)泡膠是用有毒原料做的,高溫燃燒融化后有毒,PP的就沒關(guān)系,它在國外已經(jīng)很普及了,但是在國內(nèi)還是屬于中高檔快餐用品。
Environmentally friendly tableware is a food container whose materials are harmless to human body, the production process does not pollute the environment, the product quality fully meets the national food hygiene requirements, and the product is easy to recycle, dispose or consume after use. PP is safe and healthy, non-toxic and harmless, and has high recovery value. Unlike foaming, foamed rubber is made of toxic raw materials, which are toxic after burning and melting at high temperature. It doesn't matter that PP is toxic. It has been widely used abroad, but it still belongs to medium and high-end fast food products in China.
環(huán)保餐具:[健康飯盒]產(chǎn)品是不添加填充劑的一次性環(huán)保餐盒、采用食品級PP全新進(jìn)口料、密封和不串味設(shè)計(jì)、承托力、確保在運(yùn)送快餐途中不滲漏、溢出和變形、可放入微波爐加熱和冰箱冷藏、無異味、還可為您印上凹凸店鋪大名,秀出您的酒店和餐廳、餐品價(jià)值、餐廳形象的餐盒。
Environment-friendly tableware: [Healthy lunch box] is a disposable, high-grade and environment-friendly lunch box without adding fillers, which uses new imported food-grade PP materials, safe sealing and non-smelling design, super bearing capacity, ensures no leakage, spillage and deformation during the delivery of fast food, can be heated in the microwave oven and refrigerated in the refrigerator, has no peculiar smell, and can also print the name of concave-convex shop for you, showing your hotel and restaurant, the value of the food, and the image of the restaurant.
可降解塑料是指在生產(chǎn)過程中加入一定量的添加劑(如淀粉、改性淀粉或其它纖維素、光敏劑、生物降解劑等),穩(wěn)定性下降,較容易在自然環(huán)境中降解的塑料。
Degradable plastics refer to the plastics that are easily degraded in natural environment due to the stability reduction when a certain amount of additives (such as starch, modified starch or other cellulose, photosensitizer, biodegradable agent, etc.) are added in the production process.
優(yōu)點(diǎn)是:環(huán)保衛(wèi)生——可降解塑料一般認(rèn)為是一種通過太陽光輻射或土壤中微生物使其能分解成為低分子物的塑料,它除具有可降解性外,還應(yīng)有易于加工及滿足使用要求的性能.太陽光對聚合物材料的危害作用是紫外光和氧的綜合效應(yīng),因此稱光氧化降解.以聚烯烴為例,光氧化經(jīng)常引起聚合物的斷鏈或交聯(lián),并伴隨形成一些含氧的官能團(tuán),如酮、羧酸、過氧化物和醇.其降解主要來自于聚合物中催化劑殘留物,以及加工過程中引入的過氧化物和羰基的引發(fā)作用。
The advantages are: environmental protection and hygiene - degradable plastic is generally considered as a kind of plastic that can be decomposed into low molecular substances by solar radiation or microorganisms in the soil. In addition to its degradability, it should also have the properties of easy processing and meeting the use requirements. The harmful effect of solar light on polymer materials is the combined effect of ultraviolet light and oxygen, so it is called photooxidation degradation. Take polyolefin as an example, photooxidation often causes chain breaking or cross-linking of polymer, It is accompanied by the formation of some oxygen-containing functional groups, such as ketones, carboxylic acids, peroxides and alcohols. Its degradation mainly comes from the catalyst residues in the polymer and the initiation of peroxide and carbonyl introduced in the processing process.
餐具是生產(chǎn)設(shè)備和工藝,采用PS材料出品的水晶塑料餐具產(chǎn)品,無味、晶瑩剔透、環(huán)保衛(wèi)生、不變形不滲漏
Tableware is the production equipment and technology. The crystal plastic tableware products made of PS materials are non-toxic, tasteless, crystal clear, environmentally friendly, sanitary, non-deformation, non-leakage, safe and non-toxic
環(huán)保餐具采用食品級材料PS制造,經(jīng)相關(guān)部門檢測,符合GB18006,1-2009執(zhí)行標(biāo)準(zhǔn)。
The environment-friendly tableware is made of food-grade material PS, which has been tested by relevant national departments and conforms to the national GB18006,1-2009 executive standard.
干凈無菌環(huán)保餐具是使用精密注塑設(shè)備經(jīng)過260度高溫一次注塑成型,經(jīng)紫外線后上自動(dòng)流水無菌包裝而成。外觀精致環(huán)保餐具透明晶瑩,外觀簡單精致,讓人愛不釋手。你有什么需求可以隨時(shí)來咨詢http://m.hydronic.cn我們!
Clean, sterile and environment-friendly tableware is made by using precision injection molding equipment, through one-time injection molding at 260 ℃ high temperature, after ultraviolet sterilization and disinfection, and then automatically flowing aseptic packaging. The appearance of exquisite environmental protection tableware is transparent and crystal clear, and the appearance is simple and exquisite, which makes people love it. If you have any needs, please feel free to consult http://m.hydronic.cn We!
- 上一個(gè): 生物降解材料可制成環(huán)保包裝袋的必要性!
- 下一個(gè): 凍融處理對玉米淀粉凝膠和顆粒的影響
