一次性環(huán)保餐具大概可以分為四種類型
購(gòu)買時(shí)一次性環(huán)保餐具盡量選擇表面光滑,顏色均勻,無(wú)花紋,無(wú)色透明的一次性餐盒餐具,盡量不要選擇捏起來(lái)太軟的產(chǎn)品。接下來(lái)為大家介紹一次性環(huán)保餐具大概可以分為四種類型事項(xiàng)。
When purchasing disposable environment-friendly tableware, try to choose disposable tableware with smooth surface, uniform color, no pattern, colorless and transparent, and try not to choose products that are too soft to pinch. Next, we will introduce that disposable environment-friendly tableware can be divided into four types.
Disposable cornstarch tableware:
顧名思義,它是以淀粉為原料,配以淀粉纖維等食用添加劑,通過(guò)生物復(fù)合、多糖交聯(lián)、鈣離子螯合等技術(shù)精制而成。它由密層、內(nèi)防水層、橡膠網(wǎng)層和外防水層組成。
As the name implies, it is made from starch as raw material, with starch fiber and other food additives, and refined by biological compound, polysaccharide cross-linking, calcium ion chelation and other technologies. It is composed of a dense layer, an inner waterproof layer, a rubber mesh layer and an outer waterproof layer.
紙板一次性環(huán)保餐具:
Cardboard disposable environment-friendly tableware:
快板餐具是由300-350克的漂白硫酸鹽木漿紙板,經(jīng)過(guò)類似拉絲工藝、模切或模切壓制、成型等工藝制成。為了防止?jié)B水或滲水,表面應(yīng)涂上涂層或使用化學(xué)品。然而,對(duì)紙板的質(zhì)量要求更高,成本也隨之增加。
Allegro tableware is made of 300-350 grams of bleached kraft wood pulp and paperboard through processes such as wire drawing, die-cutting or die-cutting pressing and molding. In order to prevent water seepage or water seepage, the surface shall be coated or chemicals shall be used. However, the quality requirements of paperboard are higher, and the cost also increases.
一次性環(huán)保帶漿餐具:
Disposable environmental protection tableware with pulp:
黍的木漿,如木漿、蘆葦、甘蔗渣、麥草、稻草等。,粉碎提純,加入適量化學(xué)添加劑,然后成型、烘干、定型、定型、切割、。產(chǎn)品的美觀度不高,但會(huì)增加廢水的污染。
Wood pulp of millet, such as wood pulp, reed, bagasse, wheat straw, straw, etc., Crush and purify, add appropriate chemical additives, and then shape, dry, shape, shape, . The beauty of the product is not high, but it will increase the pollution of wastewater.
植物纖維一次性環(huán)保餐具:
Plant fiber disposable environmental protection tableware:
植物纖維餐具在環(huán)保方面優(yōu)勢(shì)明顯。它是以稻草、稻殼、甘蔗渣等植物纖維為原料,添加成型劑、粘合劑、防水劑等添加劑,經(jīng)干燥、成型、等后處理而成。它們可以作為工業(yè)原料,幫助農(nóng)業(yè)資源的綜合利用。
Plant fiber tableware has obvious advantages in environmental protection. It is made of straw, rice husk, bagasse and other plant fibers as raw materials, added with molding agent, adhesive, waterproof agent and other additives, after drying, molding, disinfection and other post-processing. They can be used as industrial raw materials to help the comprehensive utilization of agricultural resources.
該餐具耐高溫、隔熱、器型美觀大方、衛(wèi)生、不燙手等一系列優(yōu)勢(shì),現(xiàn)引用到普通餐桌上的一種新型干凈衛(wèi)生的傳統(tǒng)餐具替代產(chǎn)品。你有相關(guān)需求就來(lái)我們網(wǎng)站http://m.hydronic.cn咨詢吧!
The tableware has a series of advantages, such as high temperature resistance, heat insulation, beautiful and generous shape, sanitation, and no hot hands. Now it is quoted as a new clean and sanitary substitute for traditional disinfected tableware on ordinary dining tables. Come to our website if you have relevant requirements http://m.hydronic.cn Ask!
- 上一個(gè): 為什么選擇可生物降解的顆粒?
- 下一個(gè): 可降解塑料制品是否真的可以降解呢?
