      玉米淀粉顆粒環(huán)保餐具能重復(fù)使用嗎?
      網(wǎng)址:http://m.hydronic.cn 手機頁面二維碼 2022-12-28 19:12:46
      玉米淀粉顆粒環(huán)保餐具能重復(fù)使用嗎?事實上,我們可以看到現(xiàn)在很多外賣盒,看著質(zhì)量不錯,標(biāo)注的也是比較的玉米淀粉材質(zhì),有些人就忍不住洗干凈囤在家里重復(fù)使用。但其實這是不對的!
      Can Corn Starch Granules be Reused as Environmental Protection Tableware? In fact, we can see that many takeout boxes are of good quality and labeled with safe corn starch materials. Some people can't help but wash them and store them at home for reuse. But in fact, this is wrong!
      出于成本控制等原因,通常一次性玉米淀粉餐具其制作出來的目的,就是盛裝一次、溫度較高的、可能有油的食物,在這個條件下使用,是的。但如果使用次數(shù)較多,就會破壞其穩(wěn)定性,其中的有害物質(zhì)析出,長期下來可能會影響健康!
      For cost control and other reasons, disposable corn starch tableware is usually made to contain food with high temperature and possible oil for once. It is safe to use under this condition. However, if it is used more often, its stability will be destroyed. The release of harmful substances may affect health in the long run!
      此外,還有一些使用事項要注意是否正確,比如:
      In addition, there are some matters to be noted for correct use, such as:
      有些人使用一次性玉米淀粉餐具時,為了保持密封性,會在蓋子上裝上密封圈。但食物殘渣滲入到密封圈里,就成為了霉菌的“福地”。建議每次清洗時,把密封圈及其溝槽清洗干凈,晾干后,再裝回蓋子上。餐盒的使用年限一般為3-5年,但當(dāng)其出現(xiàn)變色、變脆、變黃的情形,應(yīng)及時更換。
      When some people use disposable corn starch tableware, they will install a sealing ring on the cover to maintain the sealing. However, if food residue seeps into the sealing ring, it becomes a "blessed place" for mold. It is recommended to clean the seal ring and its groove every time it is cleaned, and then install it back on the cover after it is dried. The service life of the lunch box is generally 3-5 years, but it should be replaced in a timely manner in case of discoloration, brittleness and yellowing.
      如果一次性玉米淀粉餐具內(nèi)長時間存放酒精、碳酸飲料、醋等酸性物質(zhì),容易加快老化。所以,如果您家有自制的醋泡花生、楊梅酒等,記得不要放在一次性餐具里,不妨換成玻璃器皿儲存。
      If alcohol, carbonated drinks, vinegar and other acidic substances are stored in disposable corn starch tableware for a long time, it is easy to accelerate aging. Therefore, if you have homemade vinegar soaked peanuts, red bayberry wine, etc., remember not to put them in disposable tableware, and you may as well change them to glass containers for storage.
      有些微波爐餐盒,盒體以5號PP制造,但盒蓋卻以4號PE制造,而PE是不能抵受高溫。所以放入微波爐前,記得把蓋子取下。
      For some microwave oven lunch boxes, the box body is made of No. 5 PP, but the box cover is made of No. 4 PE, which cannot withstand high temperatures. So remember to remove the cover before putting it into the microwave oven.
      針對以上的問題點,我們已經(jīng)做出了解答,希望能夠給您好的幫助吧,您對此還有什么不能理解的地方歡迎來我們網(wǎng)站http://m.hydronic.cn留言咨詢!
      We have answered the above questions, and we hope to give you some help. If you have any questions, please come to our website http://m.hydronic.cn Message consultation!
