      沸水真的可以達(dá)到餐具的目的嗎?
      沸水真的可以達(dá)到餐具的目的嗎?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2019-03-12 14:48:20
      我們吃飯用的餐具是件頭等大事,我們常用的方式無(wú)非就是用熱水燙,但是這樣真的可以達(dá)到的目的嗎?下面我們來(lái)看看一次性玉米淀粉餐具廠家的提示吧,
      Disinfection of tableware for our meals is a top priority. The most commonly used disinfection method is hot water, but can it really achieve the purpose of disinfection? Let's take a look at the tips of disposable corn starch tableware manufacturers.
      高溫煮沸是我們?nèi)粘V谐R?jiàn)的一種方式,但是高溫也是需要兩個(gè)條件的,就是的溫度和的時(shí)間。這兩者必不可少。就比如說(shuō)引起急性腹瀉的病菌,要在100攝氏度的高溫作用三分鐘左右才能達(dá)到消滅的作用。如果溫度和時(shí)間達(dá)不到要求,這些細(xì)菌依然是可以存活的。由此可見(jiàn),要達(dá)到的作用,就必須是達(dá)到必要的條件。
      High temperature boiling is one of the most common disinfection methods in our daily life, but high temperature disinfection also requires two conditions, namely, the temperature of disinfection and the time of disinfection. Both are indispensable. For example, the bacteria causing acute diarrhea need to be treated at 100 degrees Celsius for about three minutes before they can be eliminated. If the temperature and time do not meet the requirements, these bacteria can still survive. Thus, in order to achieve the role of disinfection, it is necessary to achieve the necessary conditions.
      還有一些人會(huì)選擇用白酒來(lái)擦拭碗筷,以期望達(dá)到的做,但是你知道嗎,醫(yī)學(xué)上要達(dá)到作用的酒精濃度需要達(dá)到75%,而一般的白酒酒精濃度在65%一下,所以,使用白酒擦拭餐具,是達(dá)不到的目的的。
      Some people will choose to wipe dishes and chopsticks with liquor in order to achieve disinfection, but do you know that the medical alcohol concentration to achieve disinfection needs to reach 75%, while the general alcohol concentration of liquor is below 65%, so the use of liquor to wipe tableware, is not to achieve the purpose of disinfection.
      以上精彩內(nèi)容由安徽鑫科生物環(huán)保公司友情提供,本公司是一家經(jīng)營(yíng)一次性玉米淀粉餐具的公司,產(chǎn)品是可降解的綠色環(huán)保產(chǎn)品,,俗稱(chēng)為可以吃的塑料,是一種新型的,將來(lái)可完全有可能替代普通的一次性餐具的新產(chǎn)品。成本低,對(duì)人體有益無(wú)害,前景可觀!更多詳情請(qǐng)關(guān)注我們的官網(wǎng):http://m.hydronic.cn
      The above wonderful content is provided by the friendship of Anhui Xinke Bio-environmental Protection Company, which is a company dealing in disposable corn starch tableware. The product is degradable green environmental protection product, non-toxic, commonly known as edible plastic. It is a new type of product, which can completely replace ordinary disposable tableware in the future. Low cost, good for human body, good prospects! For more details, please pay attention to our website: http://m.hydronic.cn
