玉米淀粉顆粒有著怎么的特殊性
玉米淀粉加水有種奇異特性:受快速撞擊會(huì)變硬,受慢速撞擊反而不會(huì)。將玉米淀粉和水以約3:2之重量比混合攪拌平均,視情形增減水量,這種名為“歐不裂”oobleck的剪切增稠流體,是一種非牛頓流體。
Corn starch with water has a strange feature: it will become hard when hit quickly, but not when hit slowly. Mix corn starch and water at a weight ratio of about 3:2, and increase or decrease the amount of water as the case may be. This shear thickening fluid called "Oubuli" oobleck is a non Newtonian fluid.
1.倒出此制廢品約5mL之量于手掌,雙手搓揉即可將原先液態(tài)之制程品搓成丸子狀之固態(tài)小球,中止搓揉后約半秒后該小球?qū)⒓菜?消融"而回到液態(tài),可反復(fù)搓揉動(dòng)作演示此種特殊性質(zhì)。
1. Pour about 5mL of this waste product into the palm of your hand. Rub with both hands to make the original liquid product into a ball like solid ball. After about half a second of stopping the rubbing, the ball will quickly "melt" and return to the liquid. You can repeatedly rub to demonstrate this special nature.
2.將約50~100mL之制廢品放于免洗紙杯內(nèi),運(yùn)用免洗紙杯或塑膠杯是為了輕量化便當(dāng)操作,先悄悄傾斜紙杯給參與者觀看紙杯內(nèi)部液態(tài)的制廢品,接著快速將紙杯內(nèi)制廢品對(duì)觀眾作潑灑動(dòng)作,這種現(xiàn)象能夠令參與者印象深入。
2. Put about 50~100mL of waste products in the disposable paper cup. The disposable paper cup or plastic cup is used for lightweight and convenient operation. First, tilt the paper cup quietly to show the participants the liquid waste products inside the paper cup, and then quickly sprinkle the waste products inside the paper cup on the audience. This phenomenon can impress the participants deeply.
3.將約50~100mL之制廢品放于免洗紙杯內(nèi),先悄悄傾斜紙杯給參與者觀看紙杯內(nèi)部液態(tài)的制廢品,然后顛倒免洗杯但快速上下?lián)u擺行走一段間隔后將杯子回正,此時(shí)由于非牛頓流體產(chǎn)生力氣對(duì)立快速之剪應(yīng)變化,因而杯中之制廢品并不會(huì)潑出。
3. Place about 50~100mL of waste products in the disposable paper cup. First, tilt the cup quietly to show the participants the liquid waste products inside the cup, then turn the disposable cup upside down but swing it up and down quickly for a period of time before returning the cup. At this time, the strength generated by the non Newtonian fluid should change against the fast shear, so the waste products in the cup will not be spilled.
4.將數(shù)升之制廢品放于大型淺盆內(nèi),秦皇島玉米淀粉顆粒廠家通知您參與者能夠快速跑過(guò)淺盆中的制廢品而不下沉,若行走速度較慢則會(huì)下陷于制廢品中。
4. Put a few liters of waste products in a large shallow basin. The Qinhuangdao corn starch granule manufacturer informs you that participants can quickly run through the waste products in the shallow basin without sinking. If they walk slowly, they will sink into the waste products.
5.將50~100mL之制廢品放于朝上之聲響喇叭震動(dòng)膜上,開(kāi)啟一定音量之低頻聲波振動(dòng)及可察看制程品的扭曲成型變化。
5. Place 50~100mL of waste products on the vibrating film of the upward sounding horn, turn on the low-frequency acoustic vibration of a certain volume, and observe the distortion and molding changes of the products in process.
以上是玉米淀粉顆粒廠家為大家整理的相關(guān)內(nèi)容,想要了解更多內(nèi)容,歡迎訪問(wèn)我們網(wǎng)站http://m.hydronic.cn!
The above is the relevant content compiled by the corn starch granule manufacturer for you. If you want to know more, please visit our website http://m.hydronic.cn !
- 上一個(gè): 一次性玉米淀粉餐具的參考標(biāo)準(zhǔn)規(guī)定
- 下一個(gè): 假環(huán)保餐盒有哪些特征
