      一次性環(huán)保餐具的發(fā)展前景怎么樣
      網址:http://m.hydronic.cn 手機頁面二維碼 2022-10-06 14:44:59
      人們常常用一次性環(huán)保餐具,那么一次性環(huán)保餐具的發(fā)展前景怎么樣呢?下面就讓小編為大家詳細介紹一下吧!
      People often use disposable environment-friendly tableware. What is the development prospect of disposable environment-friendly tableware? Now let's make a detailed introduction!
      有的塑料餐具含有聚苯乙烯,在60攝氏度高溫下會釋放出致物質。人如果長期使用,攝入過量的致物質苯,身體可能會受損。
      Some plastic tableware contains polystyrene, which will release substances at a high temperature of 60 ℃. If a person uses benzene for a long time, he or she may suffer from physical damage if he or she ingests excessive amount of the causative substance benzene.
      塑料餐具雖然用起來非常方便,但不僅危害身體,對環(huán)境的污染也是很嚴重的,尤其一次性刀叉勺,使用一次之后就扔掉了,不僅沒法二次利用,而且無法工業(yè)降解,小小的刀叉勺可能需要好幾百年才能完全降解,對環(huán)境的污染是不可估量的。
      Although plastic tableware is very convenient to use, it not only harms the body, but also causes serious pollution to the environment. In particular, disposable knives, forks and spoons are thrown away after being used once, which can not be reused and can not be degraded in industry. Small knives, forks and spoons may take hundreds of years to be completely degraded, and the environmental pollution is incalculable.
      環(huán)保紙質餐盒在一定程度上可以降低降解難度,減少對環(huán)境的污染,市面上的紙質餐盒有牛皮紙餐盒,屬于卡紙工藝,但大多會有pp淋膜,達到防水防油的效果,不然餐盒會出現(xiàn)滲油和滲水的情況。這一類紙質餐盒方便印刷,是先印刷再切成型。
      Environmentally friendly paper lunch boxes can reduce the difficulty of degradation and environmental pollution to a certain extent. The paper lunch boxes on the market are kraft paper lunch boxes, which belong to the cardboard process, but most of them will have a pp coating, which can achieve the effect of water and oil resistance. Otherwise, the lunch boxes will have oil and water seepage. This kind of paper lunch box is convenient for printing. It is printed before being cut into shape.
      甘蔗漿或者小麥秸稈漿做成的紙質餐盒,是紙漿模塑工藝壓出來的餐盒,添加了食品級防水防油劑,這種餐盒不添加pp材質,屬于生物全降解,45-90天可以堆肥全降解成有機質。但這種可降解餐盒印刷比較困難,除非把logo刻到模具上,油墨印刷的成本會很高。
      The paper lunch box made of sugarcane pulp or wheat straw pulp is a lunch box pressed by the pulp molding process, with food grade waterproof and oil repellent added. This kind of lunch box does not add pp material, which belongs to full biodegradation. It can be composted and completely degraded into organic matter within 45-90 days. However, it is difficult to print this biodegradable lunch box. Unless the logo is engraved on the mold, the cost of ink printing will be high.
      一次性環(huán)保餐具會是未來的大趨勢,全球都在開始大范圍禁塑限塑了。以上就是小編為大家?guī)淼年P于一次性環(huán)保餐具的發(fā)展前景,供大家參考。您如果有需求就來我們網站http://m.hydronic.cn進行咨詢吧!
      Disposable environment-friendly tableware will be the major trend in the future, and the world is beginning to ban and limit plastic in a large range. The above is the development prospect of disposable environmental protection tableware brought by Xiaobian for your reference. Come to our website if you need http://m.hydronic.cn Consult!
