      為什么要使用可降解環(huán)保材料?
      網(wǎng)址:http://m.hydronic.cn 手機頁面二維碼 2022-09-16 16:55:08
      隨著人們的環(huán)保意識的增強,從當初的限塑令,到花樣百出的各種可降解餐具。那么如今為什么要使用可降解環(huán)保材料呢?下面可降解顆粒廠家為您分析一番。
      With the enhancement of people's awareness of environmental protection, from the original plastic restriction order to a variety of biodegradable tableware. So why should we use degradable and environment-friendly materials now? The manufacturer of degradable particles will analyze it for you.
      可降解材料是在一段時間內(nèi),在熱力學和動力學意義上均可降解的材料。
      Degradable materials are degradable materials in the sense of thermodynamics and kinetics in a period of time.
      可降解材料多為外在因素而降解,按照外因素可分為
      Degradable materials are mostly degraded by external factors, which can be divided into
      光降解材料:由于太陽光的作用而降解。
      Photodegradable material: degrades due to the action of sunlight.
      生物降解材料:由于真菌、細菌等自然界微生物的呼吸作用或化能合成而降解,終分解為二氧化碳和水。
      Biodegradable materials: they are degraded due to the respiration or chemical energy synthesis of natural microorganisms such as fungi and bacteria, and finally decomposed into carbon dioxide and water.
      環(huán)境降解材料:在光、熱、水、污染化合物、微生物、昆蟲、機械力等自然環(huán)境條件作用下降解。
      Environmental degradation materials: they are degraded under natural environmental conditions such as light, heat, water, pollution compounds, microorganisms, insects and mechanical forces.
      影響因素主要有溫度、分子量、材料結(jié)構(gòu)等。
      The main influencing factors are temperature, molecular weight, material structure, etc.
      目前主要的材料有:乳酸;淀粉塑料;光降解塑料;生物材料等。
      At present, the main materials are: lactic acid; Starch plastic; Photodegradable plastics; Biological materials, etc.
      可降解材料的特點:
      Characteristics of degradable materials:
      可以和普通垃圾一起處理,也可以作為堆肥重回大自然
      It can be treated together with ordinary garbage or returned to nature as compost
      因為可降解而使得體積減小,可以有效增長填埋場的使用壽命
      The volume is reduced due to degradation, which can effectively increase the service life of the landfill
      不存在普通塑料需要焚燒的問題,可以有效地減少有害氣體的產(chǎn)生
      There is no need to burn ordinary plastics, which can effectively reduce the generation of harmful gases
      可以減少因為隨意丟棄而產(chǎn)生的對野生動植物的危害
      It can reduce the harm to wild animals and plants caused by random discarding
      用途廣泛,不單單局限于餐飲,農(nóng)業(yè)等等行業(yè),更可用于醫(yī)療行業(yè)等
      It is widely used, not only in catering, agriculture and other industries, but also in medical industry
      可降解材料具備以上幾種特點,相比于傳統(tǒng)的塑料等材料,更加的環(huán)保,。對自然界的傷害更低。環(huán)保材料之一的可降解材料的市場前景是廣闊的,如果您對該材料產(chǎn)品有需求可以來我們網(wǎng)站http://m.hydronic.cn咨詢看看。
      Degradable materials have the above characteristics. Compared with traditional plastics and other materials, they are more environmentally friendly and energy-saving. It is less harmful to nature. The market prospect of degradable materials, one of the environment-friendly materials, is broad. If you have a demand for the material products, you can come to our website http://m.hydronic.cn Consult.
