      一次性可降解刀叉勺的使用有難度嗎?
      一次性可降解刀叉勺的使用有難度嗎?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2022-07-19 16:23:56
      一次性刀叉勺在我們的日常生活中已經(jīng)司空見慣,尤其是一次性塑料刀叉勺,在水果撈、沙拉輕食、西餐廳等餐點(diǎn)中尤為常見。那么一次性可降解刀叉勺的使用有難度嗎?
      Disposable knives, forks and spoons have become commonplace in our daily life, especially disposable plastic knives, forks and spoons, which are particularly common in fruits, salads, Western restaurants and other meals. Is it difficult to use disposable degradable knives, forks and spoons?
      日常使用的一次性塑料刀叉勺便宜,給我們的生活帶來很多好處。它們不僅可以儲存蔬菜和水果,還可以滿足我們的包裝習(xí)慣。但塑料餐具對人體有害,應(yīng)盡量減少。
      Disposable plastic knives, forks and spoons for daily use are cheap and bring many benefits to our lives. They can not only store vegetables and fruits, but also meet our packaging habits. However, plastic tableware is harmful to human body and should be minimized.
      一些塑料餐具含有聚苯乙烯,在60攝氏度的高溫下會釋放致癌物質(zhì)。如果一個人長期使用它并攝入過量的致癌物質(zhì)苯,身體可能會受到損害。
      Some plastic tableware contains polystyrene, which will release carcinogens at a high temperature of 60 degrees Celsius. If a person uses it for a long time and ingests too much carcinogen benzene, his body may be damaged.
      塑料餐具雖然使用起來非常方便,但不僅對身體有害,而且對環(huán)境造成嚴(yán)重污染,尤其是一次性餐具和勺子,一次性扔掉,不僅不能重復(fù)使用,更不能工業(yè)化退化。小刀叉勺可能需要幾百年才能完全降解,對環(huán)境的污染是無法估量的。
      Although plastic tableware is very convenient to use, it is not only harmful to the body, but also causes serious pollution to the environment. In particular, disposable tableware and spoons, thrown away at one time, can not be reused, let alone industrialized degradation. Knives, forks and spoons may take hundreds of years to completely degrade, and the pollution to the environment is immeasurable.
      甘蔗漿還可用作一次性刀、叉和勺子。你知道嗎?紙漿模塑工藝制成的一次性可降解餐具勺,采用紙漿模塑濕壓工藝,將甘蔗渣制成的植物纖維通過管道輸入成型機(jī),形成濕胚,成型后輸送熱壓機(jī),可制成純植物纖維的可降解餐具。
      Sugarcane pulp can also be used as disposable knives, forks and spoons. You know what? The disposable degradable tableware spoon made by the pulp molding process adopts the pulp molding wet pressing process to input the plant fiber made of bagasse into the molding machine through the pipeline to form a wet embryo, which is then transported to the hot press to make the degradable tableware of pure plant fiber.
      可降解顆粒廠家認(rèn)為一次性可降解勺子、一次性可降解刀、一次性可降解叉子都可以通過紙漿模壓工藝制成。但在一定程度上減少了環(huán)境的白色污染。如果是你,你會選擇甘蔗漿制成的環(huán)??山到獾恫嫔讍幔?/div>
      Degradable granule manufacturers believe that disposable degradable spoons, disposable degradable knives and disposable degradable forks can be made by pulp molding process. But to a certain extent, it reduces the white pollution of the environment. If it were you, would you choose the environmentally friendly degradable knife, fork and spoon made of sugarcane pulp?
      一次性可降解刀叉勺的使用有難度嗎?以上便是問題講解內(nèi)容了,希望能夠給您幫助,您還有什么不明白的可盡管來關(guān)注我們網(wǎng)站http://m.hydronic.cn咨詢了解。
      Is it difficult to use disposable degradable knives, forks and spoons? The above is the content of the problem explanation. I hope I can help you. If there is anything you don't understand, just follow our website http://m.hydronic.cn Consult and understand.
