      三種材料制作健康的可降解餐盒
      三種材料制作健康的可降解餐盒
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2022-06-14 14:47:12
      隨著限塑令的不斷推行,可降解成為了未來的必然趨勢,可降解產(chǎn)品也逐步替代了傳統(tǒng)塑料產(chǎn)品,細(xì)心的小伙伴們可能發(fā)現(xiàn)了打包用的一次性餐盒已經(jīng)發(fā)生了改變。在此三種材料制作健康的可降解餐盒,下面來講下。
      With the continuous implementation of the plastic restriction order, degradability has become an inevitable trend in the future, and degradable products have gradually replaced traditional plastic products. Careful partners may find that the disposable lunch boxes for packaging have changed. Here we recommend three kinds of materials to make healthy degradable lunch boxes. Let's talk about them.
      玉米淀粉可降解餐盒
      Corn starch degradable lunch box
      玉米淀粉可降解餐盒是采用天然玉米淀粉及植物纖維為基料,輔之以生物聚酯、多元醇等物質(zhì)加工而成。玉米淀粉餐盒在土壤和自然環(huán)境中可以自然降解,降解率根據(jù)餐盒成分可達(dá)60%-80%,在一定程度上可以替代塑料制品,減少對環(huán)境的白色污染。
      Corn starch degradable lunch box is made of natural corn starch and plant fiber as base materials, supplemented by bio polyester, polyols and other materials. Corn starch lunch boxes can be naturally degraded in soil and natural environment. The degradation rate can reach 60%-80% according to the composition of the lunch box. To a certain extent, it can replace plastic products and reduce white pollution to the environment.
      玉米淀粉一次性餐具是生物降解制品,以玉米淀粉為主要原料,經(jīng)高科技生產(chǎn)工藝加工而成,自然條件才可自行降解,避免了對環(huán)境的污染,節(jié)約了石油等資源,經(jīng)權(quán)威檢測部門檢測,各項衛(wèi)生理化指標(biāo)均達(dá)到標(biāo)準(zhǔn),是目前餐飲市場上普遍使用的“餐具”的理想替代品。
      Corn starch disposable tableware is a biodegradable product, which is made of corn starch as the main raw material through high-tech production process. Only under natural conditions can it be degraded by itself, avoiding environmental pollution and saving non renewable resources such as oil. According to the inspection of the national authoritative testing department, all health physical and chemical indicators have reached the national standards. It is an ideal substitute for the "sterilized tableware" commonly used in the catering market at present.
      紙漿模塑餐盒(植物纖維模塑餐盒)
      Pulp molded lunch box (plant fiber molded lunch box)
      紙漿模塑餐具產(chǎn)品,在原材料上,該一次性餐盒以麥秸稈、甘蔗渣等植物纖維為原料,通過紙漿模塑濕壓工藝成型,在紙漿中添加防水防油等食品級助劑,從而滿足食品接觸要求,制備成品。生物全降解植物纖維餐盒符合《紙漿模塑餐具》質(zhì)量檢驗標(biāo)準(zhǔn)、美國食品藥品監(jiān)督管理局(FDA)、德國新食品和飲食用品法(LFGB)、等標(biāo)準(zhǔn)化檢驗標(biāo)準(zhǔn)。
      As for the raw materials of pulp molded tableware products, the disposable lunch box takes wheat straw, bagasse and other plant fibers as raw materials and is formed through the pulp molding wet pressing process. Food grade additives such as waterproof and oil proof are added to the pulp to meet the food contact requirements and prepare the finished products. The biodegradable vegetable fiber lunch box meets the national quality inspection standard for pulp molded tableware, the US Food and Drug Administration (FDA), the German new food and dietary products act (lfgb), and other international standardized inspection standards.
      PLA可降解餐盒
      PLA degradable lunch box
      PLA可降解餐盒通常是以聚乳酸(PLA)為原料,可降解顆粒廠家認(rèn)為該類型餐盒與其他的生物降解材料共混制備而成。在2022年上,我國就使用量可降解PLA餐盒來制作運動員的餐盒、餐具,PLA可降解材料就來源于我們平時見到的玉米、紅薯、高粱等農(nóng)作物中。
      PLA degradable lunch boxes are usually made of polylactic acid (PLA) as raw material. Manufacturers of degradable particles believe that this type of lunch box is prepared by blending with other biodegradable materials. At the 2022 Winter Olympic Games, China will use degradable PLA lunch boxes to make lunch boxes and tableware for athletes. PLA degradable materials come from corn, sweet potato, sorghum and other crops we usually see.
      總之,了解產(chǎn)品的相關(guān)問題或者有關(guān)內(nèi)容,才能運用的越來越好,才能打下堅實的使用基礎(chǔ),讓自己付出的時間精力得到回報,那么如果您想了解更多信息,就來關(guān)注我們網(wǎng)站m.hydronic.cn吧,讓您滿載而歸!
      In a word, only by understanding the relevant problems or contents of the product can you use it better and better, lay a solid foundation for use, and return your time, energy and money. If you want to know more information, please follow our website www.qiluxinke COM, let you return with a full load!
