      餐廳使用一次性環(huán)保餐具已然成為好趨勢
      網(wǎng)址:http://m.hydronic.cn 手機頁面二維碼 2022-06-01 15:48:03
      日常生活中使用的瓷器、鐵器、合金、塑料等家居用品都是可以重復使用的,而用于打包和外賣的往往都是一次性的,用完就扔掉,非常浪費,也會給環(huán)境帶來 危害很大。為了減輕對環(huán)境的負擔,也從健康的角度出發(fā),開發(fā)了一種采用環(huán)保食品級材料制作一次性飯盒的新技術(shù)。 越來越多的廠家生產(chǎn)的飯盒不僅健康,而且可以回收利用,非常環(huán)保。
      Household items such as porcelain, iron, alloy and plastic used in daily life can be reused, while those used for packaging and takeout are often one-off, which are thrown away after use. It is very wasteful and will bring great harm to the environment. In order to reduce the burden on the environment and from the perspective of health and safety, a new technology for making disposable lunch boxes with environmentally friendly food grade materials was developed. The lunch boxes produced by more and more manufacturers are not only safe and healthy, but also recyclable and very environmentally friendly.
      環(huán)保一次性飯盒不僅便宜,而且方便省心。 可以一次性使用,也可以多次使用。 與一些價值連城的餐具相比,環(huán)保飯盒更加經(jīng)濟實惠。一次性飯盒清洗后可以重復使用,非常經(jīng)濟。無論是招待親友還是居家使用,環(huán)保飯盒都是健康的餐具。 為了招待陌生人,一次性使用環(huán)保盒子有效地防止了疾病的傳播。
      Environmental friendly disposable lunch boxes are not only cheap, but also convenient and worry free. It can be used once or multiple times. Compared with some valuable tableware, eco-friendly lunch boxes are more economical. Disposable lunch boxes can be reused after cleaning, which is very economical. Whether entertaining relatives and friends or using at home, the environmental protection lunch box is a healthy and safe tableware. In order to entertain strangers, the disposable environmental protection box effectively prevents the spread of diseases.
      同樣,環(huán)保飯盒絲毫不遜色于我們的傳統(tǒng)餐具。 由于環(huán)保飯盒的生產(chǎn)成本較高,需要更精致的外觀和風格。 所以,所有環(huán)保盒的廠家,外觀都非常漂亮,款式多樣,真的可以和常用的餐具媲美!
      Similarly, the eco-friendly lunch box is not inferior to our traditional tableware. Due to the high production cost of environment-friendly lunch boxes, they need more exquisite appearance and style. Therefore, all the manufacturers of environmental protection boxes have very beautiful appearance and various styles, which can really compete with the commonly used tableware!
      餐廳使用一次性餐具非常衛(wèi)生,不用來回使用的餐具;其實一次性餐具也是環(huán)保餐具,因為它是可回收的,使用后還可以用來做一些工業(yè)用品;很大的特點就是衛(wèi)生,不僅餐廳可以用,醫(yī)院也可以用,因為醫(yī)院用的一次性的比較多,也是很常見的;
      The disposable tableware used in the restaurant is very sanitary, and there is no need to use the tableware back and forth; In fact, disposable tableware is also environmentally friendly tableware, because it is recyclable and can be used to make some industrial supplies after use; The great feature is hygiene, which can be used not only in restaurants but also in hospitals, because hospitals use more disposable ones, which is also very common;
      對于一些餐廳來說,使用一次性餐具不僅是一個衛(wèi)生問題,對于一些不精通洗滌技術(shù)的餐廳來說,也是一個更好的選擇。節(jié)省人力,因為一次性出鏡對于一些餐廳來說可以節(jié)省時間和人力,是非常有利的。
      For some restaurants, using disposable tableware is not only a health problem, but also a better choice for some restaurants that are not proficient in washing technology. Save manpower, because one-time appearance can save time and manpower for some restaurants, which is very beneficial.
      耐高溫,不怕冷! 它可以承受高達110攝氏度的高溫而不熔化,可以承受零下20攝氏度的寒冷而不破裂。 它可以在微波爐中加熱或在冰箱中冷藏。
      High temperature resistance, not afraid of cold! It can withstand high temperatures of up to 110 degrees Celsius without melting, and can withstand cold temperatures of minus 20 degrees Celsius without cracking. It can be heated in a microwave oven or refrigerated in a refrigerator.
      重量輕、耐壓、易儲存; 質(zhì)地堅硬,不易變形,承重能力強。 可用作包裝盒。
      Light weight, pressure resistance and easy storage; Hard texture, not easy to deform, strong load-bearing capacity. It can be used as a packing box.
      因此,對于一家餐廳來說,使用一次性環(huán)保餐具不僅可以解決送餐時的冷餐問題,還可以讓食客隨時吃到熱餐! 對于生活品質(zhì)高的顧客,可以作為二次使用,不僅贏得口碑,也增加了食客的便利。而且如果定制餐具達到一定數(shù)量,還可以在環(huán)保盒上訂購自己的廣告,也可以為你家?guī)砀嗟目蛻艉蜕狻?/div>
      Therefore, for a restaurant, the use of disposable environment-friendly tableware can not only solve the problem of cold meals when delivering meals, but also allow diners to eat hot meals at any time! For customers with high quality of life, it can be used as a secondary use, which not only won public praise, but also increased the convenience of diners. And if the customized tableware reaches a certain amount, you can also order your own advertising on the environmental protection box, which can also bring more customers and business to your family.
      只要平時使用后能按類別分類,就可以回收利用,也可以作為其他材料使用,不浪費性能。夠嗎定制環(huán)保餐具,就來關(guān)注我們網(wǎng)站,留言或者直接撥打網(wǎng)站m.hydronic.cn電話,都可以聯(lián)系到我們。
      As long as it can be classified by category after normal use, it can be recycled or used as other materials without wasting performance. Is it enough to customize environment-friendly tableware? Just follow our website, leave a message or call www.qiluxinke Com phone, you can contact us.
