      環(huán)保講解餐具的對(duì)比!
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2022-02-14 17:39:36
      全降解餐具
      Fully degradable tableware
      以小麥秸稈、甘蔗、蘆葦、稻草等一年生草本植物纖維紙漿通過(guò)碎漿、注漿(或吸漿、撈漿)、成型、定型(或整形)、切邊、挑選、、包裝等。所用原料均為循環(huán)可再生,物理制漿方式無(wú)黑水、廢水產(chǎn)生。
      The fiber pulp of annual herbaceous plants such as wheat straw, sugarcane, reed and rice straw is crushed, grouted (or sucked or fished), shaped, shaped (or shaped), trimmed, selected, disinfected and packaged. The raw materials used are recycled and renewable, and the physical pulping method has no black water and wastewater.
      紙漿模塑餐具的優(yōu)點(diǎn):
      Advantages of pulp molded tableware:
      (1)、原料為廢紙漿或可再生的小麥、蘆葦、稻草、竹子、甘蔗、棕櫚等秸稈纖維,來(lái)源廣泛,低廉,不使用木材。
      (1) . the raw materials are waste pulp or renewable straw fibers such as wheat, reed, straw, bamboo, sugarcane and palm. They come from a wide range of sources and are cheap. Wood is not used.
      (2)、生產(chǎn)過(guò)程無(wú)廢水產(chǎn)生,無(wú)外排。來(lái)自大自然的環(huán)保容器
      (2) No waste water is produced and discharged during production. Environmentally friendly containers from nature
      (3)、產(chǎn)品防水防油
      (3) Water and oil proof products
      (4)、使用過(guò)程中可冷凍、冷凍,可微波爐加熱、可 220 度烘烤
      (4) During use, it can be frozen, frozen, heated in microwave oven and baked at 220 degrees
      (5)、產(chǎn)品可以在自然狀態(tài)下 45-90 天內(nèi)全降解,可家庭堆肥,降解后主要成分是有機(jī)質(zhì),不會(huì)產(chǎn)生任何垃圾殘留和污染。
      (5) . the product can be fully degraded in natural state within 45-90 days and can be composted at home. After degradation, the main component is organic matter and will not produce any waste residue and pollution.
      (6)、作為包裝容器具有緩沖、抗壓、防震等特點(diǎn),可以有效保護(hù)被包裝的產(chǎn)品。
      (6) As a packaging container, it has the characteristics of cushioning, compression resistance and shock resistance, which can effectively protect the packaged products.
      二、玉米淀粉餐盒
      2、 Corn starch lunch box
      主要成份有載體樹(shù)脂.玉米淀粉.偶聯(lián)劑浸潤(rùn)劑相溶劑等低分子構(gòu)成。以淀粉為原料的可食用型快餐具。它是以淀粉類植物為原料,加入膳食纖維和其他可食用類助劑經(jīng)攪拌捏合而成,它采用生物復(fù)配、聚糖交聯(lián)、鈣離子螯合等技術(shù)精制而成,有致密層、內(nèi)防水層、膠網(wǎng)層和外防水層四部分構(gòu)成。
      The main ingredients are carrier resin Corn starch It is composed of coupling agent, wetting agent, solvent and other low molecules. Edible fast food tableware with starch as raw material. It is made of starch plants as raw materials, dietary fiber and other edible additives by stirring and kneading. It is refined by biological compounding, glycan crosslinking, calcium ion chelation and other technologies. It is composed of dense layer, inner waterproof layer, rubber mesh layer and outer waterproof layer.
      國(guó)內(nèi)市面通的玉米淀粉餐具多為部分可降解餐盒,無(wú)法達(dá)到全降解的水平。
      Most of the corn starch tableware circulating in the domestic market are partially degradable lunch boxes, which can not reach the level of full degradation.
      三、紙板類餐具
      3、 Cardboard tableware
      紙板快餐具是以300-350克的漂白硫酸鹽木漿紙板為原料,通過(guò)類似鈑加工的沖壓成型工藝進(jìn)行模切黏合或模切壓制、定型等工序制成。 為防止其滲油或滲水,要在其表面淋膜或施用化學(xué)助劑。在生產(chǎn)與使用過(guò)程中對(duì)人體是、無(wú)副作用的。但對(duì)于紙板的質(zhì)量要求較高,隨之成本也提高。
      Paperboard fast tableware is made of 300-350 grams of bleached kraft wood pulp paperboard through die-cutting bonding, die-cutting pressing, shaping and other processes through a stamping process similar to sheet metal processing. In order to prevent oil or water seepage, film or apply chemical additives on its surface. In the process of production and use, it is non-toxic and has no side effects on human body. However, the quality requirements for paperboard are high, and the cost is also increased.
      以上就是今天帶給大家的知識(shí)一次性環(huán)保餐具專注行業(yè)多年,為用戶不斷的提供有價(jià)值的內(nèi)容,更多內(nèi)容請(qǐng)繼續(xù)關(guān)注我們:http://m.hydronic.cn
      The above is the knowledge brought to you today. Disposable environmental protection tableware has been focused on the industry for many years and continuously provides users with valuable content. Please continue to pay attention to us for more content: http://m.hydronic.cn
