      為什么環(huán)保餐具給孩子使用也很?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2020-12-04 16:18:14
      1)衛(wèi)生,對于孩子來說這是首位的,國標(biāo)與FDA雙重標(biāo)準(zhǔn)比較靠譜的說;
      1) Non toxic health, for children, this is the first, the national standard and FDA double standards more reliable said;
      2)環(huán)保材質(zhì),對于孩子來說保護(hù)環(huán)境盡管是件比較籠統(tǒng)的概念,但是可以從點(diǎn)滴做起,這算情懷賣點(diǎn)吧;
      2) Environmental protection materials, for children, although protecting the environment is a more general concept, but can start from the bit by bit, which is the selling point of feelings;
      3)結(jié)實(shí)耐用,摔了幾次完全木有問題,當(dāng)然,這個(gè)測試是長期的,如果每次跌落都產(chǎn)生內(nèi)部缺陷,終有爆發(fā)的一刻,不過對于孩子來說這是難免的;
      3) It's strong and durable. It's a problem if you fall several times. Of course, this test is long-term. If every drop produces internal defects, there will be an outbreak. But for children, this is inevitable;
      4)重量、體積、容積合適,孩子拿著方便,大人拿著也方便;
      4) The weight, volume and volume are suitable for children and adults;
      5)外觀不錯(cuò),設(shè)計(jì)很有創(chuàng)意,充滿個(gè)性;
      5) The appearance is good, the design is very creative, full of personality;
      6)耐高溫120℃,加熱很方便。
      6) High temperature resistance 120 ℃, heating is very convenient.
      缺點(diǎn):
      Disadvantages:
      1)防滑問題,設(shè)計(jì)上是存在的,但是實(shí)際上的用處基本不存在!
      1) Anti skid problem, design is there, but the actual use of the basic does not exist!
      2)勺子有點(diǎn)兒厚而且有點(diǎn)兒淺,叉子的設(shè)計(jì)與作用跟勺子類似,頭兒這么圓……
      2) The spoon is a little thick and shallow. The fork is similar in design and function to a spoon. The head is so round
      3)偏高。
      3) The price is on the high side.
      總的來說,優(yōu)點(diǎn)多于缺點(diǎn),值得入手,畢竟難得有個(gè)既衛(wèi)生又結(jié)實(shí)的碗!塑料的怕有雙酚A同時(shí)擔(dān)心加熱時(shí)出問題,不銹鋼的盡管結(jié)實(shí)但是摔兩下也容易變形而且無法使用微波爐。
      Generally speaking, the advantages are more than the disadvantages, which is worth starting with. After all, it is rare to have a bowl that is both hygienic and strong! Plastic is afraid of bisphenol A, and worry about heating problems. Although stainless steel is strong, it is easy to deform after falling twice and can't use microwave oven.
