可生物降解的餐具主要的講解的方式有哪些?
1.有許多的環(huán)保飯盒可以作為一次性飯盒也可以作為多次使用。相比一些價(jià)值連城的餐具,環(huán)保飯盒更經(jīng)濟(jì)。一次性餐盒都在清洗后可再次利用,非常的經(jīng)濟(jì)實(shí)惠。
1. There are many environmental protection lunch boxes that can be used as disposable lunch boxes or multiple use. Compared with some priceless tableware, environmentally friendly lunch boxes are more economical. Disposable lunch boxes can be reused after cleaning, which is very economical.
2.衛(wèi)生。無論是招待親朋好友或者居家使用,環(huán)保飯盒都是健康、的餐具。對(duì)于招待陌生人,環(huán)保盒的一次性使用有效防止疾病的傳播。
2. Hygiene. Whether it is to entertain relatives and friends or to use at home, environmental protection lunch boxes are healthy and safe tableware. For entertaining strangers, the disposable use of environmental protection box can effectively prevent the spread of disease.
3.環(huán)保飯盒與我們傳統(tǒng)的餐具相比絲毫不遜色。環(huán)保飯盒由于制作工藝成本高昂,所以更需要精美的外觀和款式。所以,凡是環(huán)保盒生產(chǎn)的廠家他們的外觀非常精美,風(fēng)格也多種多樣,真的可以與常用的餐具媲美!
3. Compared with our traditional tableware, the environment-friendly lunch box is no inferior. Due to the high cost of production technology, environmental protection lunch boxes need more exquisite appearance and style. Therefore, all the manufacturers of environmental protection box have very beautiful appearance and various styles, which can be compared with common tableware!
4.耐高溫、不懼寒冷!可以承受110攝氏度的高溫。
4. Resistant to high temperature and cold! It can withstand 110 degrees centigrade.
就是那些看似塑膠的一次性快餐碗碟、刀叉,扔掉后,在泥土里分解都不會(huì)對(duì)環(huán)境造成白色污染的產(chǎn)品。例如,用玉米淀粉為原材料做成的一次性生物可降解刀叉、杯碟、飯盒,這種產(chǎn)品比起一次性塑膠餐具更加環(huán)保,使用更加。
It is the products that look like plastic disposable fast food dishes, knives and forks, which will not cause white pollution to the environment after being thrown away and decomposed in the soil. For example, disposable biodegradable knives and forks, cups, dishes and lunch boxes made of corn starch are more environmentally friendly and safer than disposable plastic tableware.
生物降解塑料是一種具有優(yōu)良的使用性能、廢棄后可被環(huán)境微生物完全分解、更終被無機(jī)化而成為自然界中碳素循環(huán)的一個(gè)組成部分的高分子材料。眾所周知,“紙”是一種典型的生物降解材料,而“合成塑料”則是典型的高分子材料。那么,生物降解塑料是兼有“紙”和“合成塑料”這兩種材料性質(zhì)的高分子材料。
Biodegradable plastic is a kind of polymer material with excellent performance, which can be completely decomposed by environmental microorganisms after waste, and finally be inorganic, and become a part of carbon cycle in nature. As we all know, "paper" is a typical biodegradable material, while "synthetic plastic" is a typical polymer material. Therefore, biodegradable plastics are polymer materials with the properties of "paper" and "synthetic plastics".
聚合物的降解有四種主要方式:微生物降解、大型生物降解、光降解和化學(xué)降解。光降解和生物降解塑料的定義是指通過自然日光作用發(fā)生光氧化降解并在光降解達(dá)到衰變期后可繼續(xù)被微生物降解的一類塑料稱為光—生物降解塑料。
There are four main ways of polymer degradation: microbial degradation, large-scale biodegradation, photodegradation and chemical degradation. The definition of photodegradation and biodegradable plastics refers to a kind of plastics which can be degraded by microorganism after the photodegradation reaches the decay period through the action of natural sunlight.
感謝您的閱讀,此文的文章來源:一次性環(huán)保餐具更多的內(nèi)容和問題請(qǐng)點(diǎn)擊:http://m.hydronic.cn我們會(huì)繼續(xù)努力的為您提供服務(wù),感謝您的支持!
Thank you for your reading. The article source: disposable environmental protection tableware. For more information and questions, please click: http://m.hydronic.cn We will continue to work hard to provide services for you, thank you for your support!
- 上一個(gè): 可生物降解的餐具主要的講解的方式有哪些?
- 下一個(gè): 玉米餐具是我們聽說的“能吃的餐具嗎?”
