      一次性淀粉餐具是如何用設(shè)備生產(chǎn)出來?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2020-08-19 16:11:25
      1、脫模機(jī)構(gòu)的選型:
      1. Selection of demoulding mechanism:
      脫模機(jī)構(gòu)的驅(qū)動(dòng)主要有兩種,即氣缸驅(qū)動(dòng)或油缸驅(qū)動(dòng),為便于成型機(jī)各機(jī)構(gòu)的有益配合,擬定采用油缸驅(qū)動(dòng)。
      There are two main types of demoulding mechanism driving, namely cylinder driving or oil cylinder driving. In order to facilitate the beneficial cooperation of various mechanisms of molding machine, it is proposed to adopt cylinder drive.
      2、上料機(jī)構(gòu):
      2. Feeding mechanism:
      上料機(jī)構(gòu)主要有兩種形式:
      There are two main types of feeding mechanism
      (1)稱重式上料機(jī)構(gòu):
      (1) Weighing feeding mechanism:
      稱重式上料機(jī)構(gòu)是取定一定重量的物料喂到模具中,其優(yōu)點(diǎn)是可以獲得準(zhǔn)確的上料量,缺點(diǎn)是需要一套復(fù)雜的機(jī)械電子機(jī)構(gòu),因而增加機(jī)構(gòu)的造價(jià)。
      The weighing feeding mechanism is to take a certain weight of material and feed it into the mold. Its advantage is that it can obtain accurate feeding amount, but the disadvantage is that it needs a set of complex mechanical and electronic mechanisms, so it increases the cost of the mechanism.
      (2)定容式上料機(jī)構(gòu):
      (2) Constant volume feeding mechanism:
      定容式上料機(jī)構(gòu)是取定一定容積的物料喂到模具中,其的優(yōu)點(diǎn)是機(jī)構(gòu)簡(jiǎn)單、造價(jià)廉,缺點(diǎn)是較難得到準(zhǔn)確的上料量。
      The constant volume feeding mechanism is to take a certain volume of material and feed it into the mold. Its advantages are simple mechanism and low cost, but the disadvantage is that it is difficult to get accurate feeding amount.
      中盤所需要的原料不是相當(dāng)準(zhǔn)確,允許有一定的誤差,故擬定采用定容式上料機(jī)構(gòu)。
      The raw material needed by the middle plate is not quite accurate, and there is a certain error allowed, so the fixed volume feeding mechanism is proposed.
      3、攤料機(jī)構(gòu):
      3. Spreading mechanism:
      一次性餐具模具推料機(jī)構(gòu)的作用是利用上模的旋轉(zhuǎn),在加壓之前將料推開,以保障壁厚均勻,擬采用液壓馬達(dá)驅(qū)動(dòng)方式。
      The function of pushing mechanism of disposable tableware mold is to use the rotation of upper mold to push the material away before pressurization, so as to ensure uniform wall thickness. It is planned to adopt hydraulic motor driving mode.
      4、回轉(zhuǎn)機(jī)構(gòu):
      4. Rotary mechanism:
      轉(zhuǎn)機(jī)構(gòu)的作用是轉(zhuǎn)換工位,主要有以下幾種方式:
      The function of the rotating mechanism is to change the station, mainly in the following ways:
      (1)輪槽間歇機(jī)構(gòu):
      (1) Groove intermittent mechanism:
      此種方式優(yōu)點(diǎn)是結(jié)構(gòu)簡(jiǎn)單,但有沖擊、加工精度高,只適合功率的較小的場(chǎng)合
      The advantages of this method are simple structure, but impact, high machining accuracy, only suitable for small power occasions
      (2)棘輪棘爪間歇機(jī)構(gòu):
      (2) Intermittent mechanism of ratchet and pawl:
      棘輪棘爪間歇機(jī)構(gòu)是一種常見的傳動(dòng)機(jī)構(gòu),缺點(diǎn)是噪音大,大多用在輔助機(jī)構(gòu)
      Ratchet and pawl intermittent mechanism is a common transmission mechanism, which has the disadvantage of high noise and is mostly used in auxiliary mechanism
      (3)齒輪-齒圈傳動(dòng):
      (3) Gear ring gear drive:
      齒輪-齒圈傳動(dòng)是工程機(jī)械中常用的驅(qū)動(dòng)方式,技術(shù)成熟,但是造價(jià)比較高。
      Gear ring gear transmission is a commonly used driving mode in construction machinery, with mature technology but high cost.
      (4)齒輪-銷齒傳動(dòng):
      (4) Gear pin tooth drive:
      齒輪-銷齒傳動(dòng)是齒輪-驅(qū)動(dòng)的變種,由于銷輪的輪齒是圓銷,與一般齒輪相比,具有結(jié)構(gòu)簡(jiǎn)單、加工方便、造價(jià)底、拆修方便等優(yōu)點(diǎn),故以其代替尺寸較大的漸開線齒輪時(shí),有較大的優(yōu)良性。比較齒輪-齒圈傳動(dòng)越加適合在成型機(jī)上使用。
      Gear pin gear transmission is a variation of gear drive. Compared with general gears, pin gear transmission has the advantages of simple structure, convenient processing, low cost and convenient disassembly and repair. Therefore, it has great advantages when replacing involute gear with larger size. The gear ring gear transmission is more suitable for use in molding machine.
      本文由一次性玉米淀粉餐具整理發(fā)布,您是不是對(duì)這些內(nèi)容有所了解了呢?更多的內(nèi)容請(qǐng)點(diǎn)擊:http://m.hydronic.cn
      This article is published by disposable corn starch tableware. Do you have any understanding of these contents? For more information, please click http: http://m.hydronic.cn
