      面對疫情我們是不是更應(yīng)該使用一次性餐具?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2020-07-27 15:26:09
      很多人在外用餐的時候喜歡用一次性餐具用品,認(rèn)為它既方便又衛(wèi)生,使用后也不用清洗,一扔了之。然而,這種選擇會帶來健康衛(wèi)生和環(huán)境保護(hù)方面的問題。經(jīng)常使用劣質(zhì)一次性餐具,對人體的健康危害顯而易見。劣質(zhì)的產(chǎn)品由于低廉,幾分錢就能買到一個,因此受到一些小飯店的歡迎。提醒,更好不要用。其原料不排除是用工業(yè)塑料,甚是廢塑料再利用的可能。如何辨別可以遵循三個步驟:先看生產(chǎn)包裝袋上的信息,生產(chǎn)日期、保質(zhì)期、生產(chǎn)許可和編號(QS標(biāo)識),是否出自正規(guī)的生產(chǎn)廠家;再辨顏色,五顏六色的盡量別買,顏色深的要特別注意,如有異味,說明肯定是問題。
      Many people like to use disposable tableware when dining out. They think it's convenient and hygienic. They don't need to clean it after use. However, this choice will bring health and environmental protection problems. Often use inferior disposable tableware, the harm to human health is obvious. Inferior products are popular in small hotels because they are cheap and can be bought for a few cents. Experts remind, better not to use. The possibility of using industrial plastics or even waste plastics for reuse is not ruled out. How to distinguish can follow three steps: first, look at the information on the production packaging bag, production date, shelf life, production license and number (QS identification), whether it is from a regular manufacturer; then identify the color, try not to buy colorful, dark color to pay special attention to, if there is odor, it must be a problem.
      其實(shí)在日常生活中如果使用的產(chǎn)品透明透亮完全可以放心使用,因?yàn)榛旧纤蔷郾┰虾途郾揭蚁┰弦淮渭庸こ尚偷模^程當(dāng)中未添加任何助劑以及添加劑;如果是乳白色的,就請不要使用,因?yàn)榧庸み^程當(dāng)中添加了色母粒原料或者色粉以降低成本。
      In fact, in daily life, if the product used is transparent and transparent, it can be safely used, because it is basically polypropylene raw materials and polystyrene raw materials processed at one time, and no additives and additives are added in the process; if it is milky white, please do not use it, because the color Masterbatch raw materials or color powder are added in the processing process to reduce the cost.
      幾乎每年都有食品的新法規(guī)出臺,顯示了維護(hù)人民群眾健康的信心,對材料生產(chǎn)方面嚴(yán)格要求。一次性水晶餐具采用的食品級的PS材質(zhì)是一種硬質(zhì)的塑料,雖然對人體無害,但是如果被丟棄后是不容易降解的。一次如果大量使用一次性水晶餐具不加以規(guī)范爭取的處理方法,會造程對自然環(huán)境的污染,而且只是用一次就被丟棄對于有著勤儉節(jié)約的美德的來說是太浪費(fèi)了。事實(shí)上的確如此,因?yàn)檫@個原材料在工業(yè)上使用極為廣泛,使用后可回收,作為再生材料加工利用可生產(chǎn)家電類工業(yè)產(chǎn)品,減輕對環(huán)境的影響。
      Almost every year, new laws and regulations on food safety are issued, which shows the confidence of maintaining people's health and safety and strict requirements on material production. The food grade PS material used in disposable crystal tableware is a kind of hard plastic, which is harmless to human body, but it is not easy to degrade if it is discarded. If a large number of disposable crystal tableware is not standardized, it will pollute the natural environment, and it will be discarded only once. It is too wasteful for China, which has the virtue of thrift and diligence. In fact, it is, because this raw material is widely used in industry and can be recycled after use. It can be processed and utilized as a renewable material to produce industrial products of household appliances and reduce the impact on the environment.
      很多朋友也會擔(dān)心是不是這個餐具在使用完后,飯店會不會收起來洗一下在重新使用,不就和餐具一樣不衛(wèi)生了。我們可直接通過肉眼觀看其有無雜質(zhì)及污漬、有無指紋及劃痕來判斷產(chǎn)品質(zhì)量、有無二次使用。
      Many friends will also worry about whether the tableware will be collected, washed and reused in the hotel after use. It will be as unsanitary as disinfected tableware. We can directly through the naked eye to see whether there are impurities and stains, fingerprints and scratches to judge the quality of the product and whether it is used again.
      一次性餐具就是原來飛機(jī)上使用的一次性水晶餐具,進(jìn)過改良后用到了普通餐飲市場中,使用的是食品級的PS聚苯乙烯材料。這個材料是對人體無害的。采用精密的注塑機(jī)器,經(jīng)過260度的溫度一次性生產(chǎn)成型,經(jīng)紫外線,無菌包裝。具有一次性使用,干凈衛(wèi)生造型精美,綠色環(huán)保等特點(diǎn)。
      Disposable tableware is the original disposable crystal tableware used on the plane. After being improved, it is used in the ordinary catering market, using food grade PS polystyrene material. This material is harmless to human body. Using precision injection molding machine, through 260 degrees of temperature one-time production molding, UV sterilization, aseptic packaging. It has the characteristics of disposable use, clean and sanitary, exquisite modeling, green environmental protection and so on.
