      一次性餐具的顏色偏黃是廢紙做的嗎?
      一次性餐具的顏色偏黃是廢紙做的嗎?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁(yè)面二維碼 2020-05-18 10:55:00
        按照標(biāo)準(zhǔn),從杯邊到杯身15mm范圍內(nèi),從杯底到杯身10mm范圍內(nèi),不能印刷圖案,也不能使用回收材料制作紙杯。昨日,記者隨機(jī)選購(gòu)了3種不同的一次性紙杯送省質(zhì)檢院鑒定,省質(zhì)檢院當(dāng)場(chǎng)為公眾選購(gòu)紙杯。
        According to the standard, it is not allowed to print patterns or use recycled materials to make paper cups within the range of 15mm from the edge of the cup to the body and 10 mm from the bottom of the cup to the body. Yesterday, reporters randomly selected three kinds of disposable paper cups of different brands and sent them to the Provincial Quality Inspection Institute for identification. Experts from the provincial quality inspection institute bought paper cups for the public on the spot.
        不要印在杯口和杯底附近
        Do not print near the mouth and bottom of the cup
        6月1日正式實(shí)施的新紙杯標(biāo)準(zhǔn)是的標(biāo)準(zhǔn)。省質(zhì)監(jiān)局有關(guān)人士表示,新標(biāo)準(zhǔn)比現(xiàn)行行業(yè)標(biāo)準(zhǔn)或企業(yè)標(biāo)準(zhǔn)更加規(guī)范,目前紙杯沒(méi)有其他標(biāo)準(zhǔn)。本標(biāo)準(zhǔn)實(shí)施后,紙杯質(zhì)量檢測(cè)基本按照新的標(biāo)準(zhǔn)進(jìn)行。
        The new paper cup national standard officially implemented on June 1 is the recommended national standard. The Provincial Quality Supervision Bureau said that the new national standards are more standardized than the current industry standards or enterprise standards, and there are no other national standards for paper cups at present. After the implementation of this standard, the paper cup quality inspection is basically carried out in accordance with the new national standard.
        新的標(biāo)準(zhǔn)明確要求,紙杯的印刷圖案在外面應(yīng)該清楚在大綱,統(tǒng)一的顏色和沒(méi)有明顯的彩色斑點(diǎn),和“杯子不應(yīng)該印刷在15毫米的杯嘴的杯體和杯底的10毫米,杯體”。
        The new national standard clearly requires that the printing pattern of paper cup should be clear on the outline, uniform color and no obvious color spots, and "the cup should not be printed on the cup body of 15 mm cup mouth and 10 mm cup bottom, cup body".
        省質(zhì)檢總局塑料與化工產(chǎn)品檢驗(yàn)所的工程師郭永梅(音譯)說(shuō),當(dāng)人們喝咖啡時(shí),嘴唇碰到杯子的邊緣,印刷圖案中的墨水可能會(huì)被咽下去。目前我國(guó)使用的油墨基本上都是含苯的油墨,對(duì)人體健康有害。同時(shí)在紙杯上,如果杯子底部有印刷圖案,很容易將顏色蹭到墻上的另一個(gè)杯子上。
        Guo Yongmei, an engineer at the plastic and chemical products inspection institute of the Provincial Quality Inspection Bureau, said that when people drink coffee and their lips touch the edge of the cup, the ink in the printed pattern may be swallowed. At present, the ink used in China is basically benzene containing ink, which is harmful to human health. At the same time, if there is a printed pattern on the bottom of the paper cup, it is easy to rub the color against another cup on the wall.
        此外,該標(biāo)準(zhǔn)規(guī)定,回收材料不得用于制作紙杯。該標(biāo)準(zhǔn)還規(guī)定了紙杯的硬度和滲透性。紙杯的底部和側(cè)面不能漏水或滲水。
        In addition, the standard states that recycled materials shall not be used to make paper cups. The standard also specifies the hardness and permeability of paper cups. The bottom and side of the paper cup shall be free from water leakage or seepage.
        減價(jià)出售的紙杯上有圖案
        The paper cups on sale have patterns on them
        近日,記者到、小賣(mài)部、食品點(diǎn)走訪時(shí)發(fā)現(xiàn),大多數(shù)紙杯的印刷圖案覆蓋了整個(gè)杯體,有的杯體過(guò)于柔軟,質(zhì)量不佳,參差不齊。如果按照新標(biāo)準(zhǔn)的要求來(lái)判斷,大多數(shù)紙杯都沒(méi)有達(dá)到標(biāo)準(zhǔn)。
        Recently, when visiting supermarkets, small shops and food outlets, reporters found that most of the printed patterns of paper cups cover the whole cup body, some of which are too soft, poor in quality and uneven in price. If judged according to the requirements of the new national standard, most paper cups are not up to the standard.
        記者在新花都、永輝等發(fā)現(xiàn),在銷(xiāo)售紙杯時(shí),包裝上標(biāo)有廠家信息、QS認(rèn)證、實(shí)施標(biāo)準(zhǔn)、材料、生產(chǎn)日期、保質(zhì)期、貯存條件等相關(guān)信息。記者在楊橋路一家便利店買(mǎi)了一個(gè)一次性紙杯,3元一個(gè)包,50元一個(gè),紙杯很軟,一捏變形。外包裝上只有生產(chǎn)商的信息,聯(lián)系方式,生產(chǎn)日期和保質(zhì)期。
        Reporters in New Huadu, Yonghui and other supermarkets found that when selling paper cups, the packaging was marked with manufacturer information, QS certification, implementation standards, materials, production date, shelf life, storage conditions and other relevant information. Reporter bought a disposable paper cup in a convenience store on Yangqiao Road, 3 yuan for a bag, 50 yuan for a bag. The paper cup is very soft and deformed. Only the manufacturer's information, contact information, production date and shelf life are on the outer package.
        顏色為黃色的紙杯原料或廢紙
        Raw material or waste paper of paper cup with yellow color
        記者挑選和購(gòu)買(mǎi)的紙杯中,有一個(gè)紙杯杯面偏黃。省質(zhì)檢院工程師郭永梅(音譯)表示,之所以會(huì)出現(xiàn)這種黃水杯,可能是因?yàn)樵牧系倪x擇不合格。一方面,它可以處理與回收廢紙。另一方面,可以用甘蔗漿代替木漿加工。這兩種原料加工出來(lái)的紙杯杯面會(huì)呈黃色。
        Among the paper cups selected and purchased by reporters, one of them has a yellow surface. Guo Yongmei, an engineer at the provincial quality inspection institute, said that the yellow water cup may be caused by the selection of raw materials. On the one hand, it can process and recycle waste paper. On the other hand, sugarcane pulp can be used instead of wood pulp. The surface of the paper cup made of these two materials will be yellow.
        而另一個(gè)選購(gòu)的杯子,一捏變形,郭永梅介紹,這種紙杯硬度不夠,是材料的選擇不造成的,可能有使用廢料產(chǎn)生。
        Another optional cup, a pinch deformation, Guo Yongmei introduced that the hardness of this paper cup is not enough, which is not caused by the selection of materials, and may be generated by using waste materials.
        以上是一次性玉米淀粉餐具廠家為大家介紹的相關(guān)內(nèi)容,想要了解更多內(nèi)容,歡迎訪問(wèn)網(wǎng)站:http://m.hydronic.cn
        The above is the relevant content introduced by the disposable corn starch tableware manufacturer. To learn more, please visit the website: http://m.hydronic.cn
