一次性環(huán)保餐具與其他餐具的對(duì)比
普通的塑料餐具
Ordinary plastic tableware
經(jīng)檢測(cè),部分塑料奶瓶顏色圖案中的鉛、鉻等重金屬元素超標(biāo)。因此,消費(fèi)者應(yīng)盡量選擇沒(méi)有裝飾圖案的無(wú)色無(wú)味的塑料餐具。另外,購(gòu)買方便碗面時(shí),應(yīng)注重觀察碗底的標(biāo)記,標(biāo)記為“PS”(聚苯乙烯)或“PP”(聚丙烯)即可放心使用。而由于泡沫塑料碗中含有發(fā)泡劑,泡在熱水中后,發(fā)泡劑中的有害氨化合物會(huì)溶解,隨食物進(jìn)入體內(nèi)。
After testing, some of the color patterns of plastic milk bottles in lead, chromium and other heavy metal elements exceeded the standard. Therefore, consumers should try to choose colorless and tasteless plastic tableware without decorative patterns. In addition, when buying convenient noodles, you should pay attention to the mark on the bottom of the bowl, which can be used safely if it is marked as "PS" (polystyrene) or "PP" (polypropylene). However, because of the foaming agent in the foam bowl, the harmful ammonia compounds in the foaming agent will dissolve and enter into the body with food after soaking in hot water.
餐具
Disinfection tableware
陶瓷餐具現(xiàn)在可以在酒店和餐館買到,在過(guò)去它被認(rèn)為是高檔和衛(wèi)生的。而現(xiàn)在,陶瓷餐具的過(guò)程已經(jīng)曝光,我們意識(shí)到原來(lái)所謂的就是用臟水清洗,用抹布擦拭。當(dāng)你吃東西的時(shí)候,餐具看起來(lái)很干凈,但是上面的數(shù)億細(xì)菌會(huì)給你留下持久的印象。許多用餐者用沸水重新開(kāi)始用餐。另外,用劣質(zhì)粘土制成的陶瓷餐具多含有微生物和有害物質(zhì),長(zhǎng)期使用會(huì)與食品一起進(jìn)入人體,危害健康。
Ceramic tableware is now available in hotels and restaurants, and in the past it was considered high-end and hygienic. Now, the disinfection process of ceramic tableware has been exposed. We realize that the original so-called disinfection is to clean with dirty water and wipe with a rag. When you eat, the tableware looks clean, but the hundreds of millions of bacteria on it will leave a lasting impression on you. Many diners start over with boiling water. In addition, ceramic tableware made of poor clay contains microorganisms and harmful substances, which will enter into human body together with food for a long time and harm health.
以上是一次性環(huán)保餐具廠家為大家介紹的相關(guān)內(nèi)容,想要了解更多內(nèi)容,歡迎訪問(wèn)網(wǎng)站:http://m.hydronic.cn
The above is the relevant content introduced by disposable environmental protection tableware manufacturers. To learn more, please visit the website: http://m.hydronic.cn
- 上一個(gè): 一次性筷子太白大家需要注意
- 下一個(gè): 一次性餐具快速鋪貨策略!
