一次性餐具為什么越來越得人心?
近年來,一次性餐具悄然出現(xiàn)在人們的餐桌上。由于這種餐具受到消費者的廣泛喜愛,米村的許多飯店都用它來代替原來的“碗筷”。
In recent years, disposable tableware has quietly appeared on people's tables. Because this kind of tableware is widely loved by consumers, many restaurants in Micun use it to replace the original "disinfected dishes and chopsticks".
記者發(fā)現(xiàn),這種一次性餐具拿起來比較輕便,而且硬度適中,手感光滑。據(jù)介紹,其良好的透明度(透光率是88% - -92%)和表面光澤,硬度高,鋼很好,此外,還具有良好的耐水、耐化學(xué)腐蝕和加工流動性能,其透明度使玻璃產(chǎn)品-1.4倍1.15倍,完全不同于之前的市場使用一次性塑料碗。
The reporter found that this kind of disposable tableware is relatively light, moderate hardness and smooth hand feel. According to reports, its good transparency (transmittance is 88% - 92%) and surface luster, high hardness, good steel, in addition, it also has good water resistance, chemical corrosion resistance and processing flow performance, its transparency makes glass products - 1.4 times 1.15 times, completely different from the previous market use of disposable plastic bowl.
根據(jù)一次性餐具負責(zé)人,他們選擇了材料,從超過500種可食用級塑料原材料的篩選,這個原料制成的成品,一旦沾水和油,清洗不能出現(xiàn)透明,和將離開小黑點,杜絕交叉污染的重用。此外,精密注塑生產(chǎn)過程中使用的設(shè)備已經(jīng)注入高溫260℃在單個注塑、自動裝配線上的紫外線后無菌包裝,取得了ISO9001質(zhì)量認證,并通過了多個部門的質(zhì)量檢測。
According to the person in charge of disposable tableware, they selected materials from the selection of more than 500 edible plastic raw materials. Once the finished product made of this raw material is contaminated with water and oil, the cleaning cannot be transparent, and it will leave small black spots and eliminate the reuse of cross pollution. In addition, the equipment used in the process of precision injection molding has been injected into the sterile packaging after UV sterilization in a single injection molding and automatic assembly line at a high temperature of 260 ℃, which has obtained ISO9001 quality certification and passed the quality test of many departments.
以上是一次性餐具廠家為大家介紹的相關(guān)內(nèi)容,想要了解更多內(nèi)容,歡迎訪問網(wǎng)站:http://m.hydronic.cnThe above is the relevant content introduced by disposable tableware manufacturers. To learn more, please visit the website: http://m.hydronic.cn
- 上一個: 一次性塑料餐具的包裝上的QS標(biāo)志重要嗎?
- 下一個: 環(huán)保餐具其實就在我們身邊
