      一次性環(huán)保餐具可以用微波爐加熱的有哪些呢?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2019-12-11 14:41:45
        可以這么說,只要外殼不導(dǎo)電的器皿可以作為一次性飯盒使用,一般情況下,只要沒有金屬材料就可以作為器皿使用。應(yīng)特別注意下列各點(diǎn):
        It can be said that as long as the shell of non-conductive utensils can be used as disposable lunch boxes, in general, as long as there is no metal material can be used as utensils. Special attention should be paid to the following points:
        一,但是你的食物不能燃燒膠水。就像骨頭一樣,要注意不要加熱太久。如果骨頭燒壞了,你的午餐盒也會(huì)燒壞。
        One, but your food can't burn glue. Just like bones, be careful not to heat them too long. If the bone burns, so does your lunch box.
        二、一次性環(huán)保餐具可以放入微波爐中加熱,但更好不要這樣加熱,一次性飯盒在微波爐中加熱,會(huì)釋放有害物質(zhì),經(jīng)常使用會(huì)造成身體損傷。
        2. Disposable environmental protection tableware can be put into microwave oven for heating, but it is better not to do so. If disposable lunch box is heated in microwave oven, harmful substances will be released, and regular use will cause physical injury.
        那么,微波加熱應(yīng)該使用什么樣的器具呢?
        So, what kind of appliance should microwave heating use?
        1. 陶瓷制品:有耐熱陶瓷和普通陶瓷。耐熱陶瓷由鍋、碟等器皿制成,適合長(zhǎng)時(shí)間在微波爐中使用,而普通陶瓷器皿只能用短時(shí)間加熱。非凡要提醒,含金、銀線的陶瓷器皿,在微波爐使用時(shí)打火花,故不宜使用。
        1. Ceramic products: there are heat-resistant ceramics and ordinary ceramics. Heat resistant ceramics are made of pots, saucers and other utensils, which are suitable for long-term use in microwave ovens, while ordinary ceramic utensils can only be heated in a short time. Especially want to remind, the ceramic utensil that contains gold, silver line, when use in microwave oven dozen spark, it is unfavorable to use so.
        2. 塑料器皿:聚丙烯、聚丙烯樹脂、復(fù)合聚丙烯、聚砜等材料制成的各種器皿,耐120℃以上的溫度,可用于微波加熱。PET樹脂、聚酯材料制成的器皿,耐高溫可達(dá)220攝氏度,可用于燒烤。當(dāng)然一次性食品盒,微波爐為聚丙烯。
        2. Plastic utensils: all kinds of utensils made of polypropylene, polypropylene resin, composite polypropylene, polysulfone and other materials, resistant to temperature above 120 ℃, can be used for microwave heating. The utensils made of PET resin and polyester can withstand high temperature up to 220 ℃, and can be used for barbecue. Of course, the disposable food box, microwave oven for polypropylene.
        3.玻璃器皿:包括硼硅酸鹽玻璃、微晶玻璃和氧化鈦晶體玻璃。微波穿透性好,理化性能穩(wěn)定,耐高溫(可達(dá)500℃甚1000℃),適合在微波爐中長(zhǎng)期使用。
        3. Glassware: including borosilicate glass, microcrystalline glass and titanium oxide crystal glass. Microwave penetration is good, physical and chemical properties are stable, high temperature resistance (up to 500 ℃ or even 1000 ℃), suitable for long-term use in microwave oven.
        4. 金屬器皿:由鋁、不銹鋼、搪瓷等各種金屬材料制成的器皿,由于微波不能穿透,所以食物不能加熱,所以不適合在微波爐中使用。
        4. Metal utensils: utensils made of aluminum, stainless steel, enamel and other metal materials. Because the microwave cannot penetrate, the food cannot be heated, so they are not suitable for use in the microwave oven.
        以上是一次性環(huán)保餐具廠家為大家介紹的相關(guān)內(nèi)容,想要了解更多產(chǎn)品信息,歡迎訪問網(wǎng)站:http://m.hydronic.cnThe above is the introduction of disposable environmental tableware manufacturers. To learn more about the products, please visit the website: http://m.hydronic.cn
