      餐具清洗有哪些誤區(qū)值得我們注意?
      網(wǎng)址:http://m.hydronic.cn 手機(jī)頁面二維碼 2019-07-25 16:36:56
      在我們的日常生活中,每天都要做飯的,所以只要在家用餐就一定會(huì)用到碗筷,那么在吃完了飯之后,很多人也都知道洗碗是一件很重要的事情,畢竟病從口入,每天使用過的碗,也都會(huì)及時(shí)清洗干凈,避免滋生細(xì)菌,下面一次性餐具廠家就給大家總結(jié)常見的清洗餐具誤區(qū),希望對(duì)大家有所幫助!
      In our daily life, we make meals every day, so as long as we eat at home, we will use chopsticks. After eating, many people also know that washing dishes is a very important thing. After all, diseases from the mouth, the bowls used every day, will also be cleaned in time to avoid germs. The next one Secondary tableware manufacturers will summarize common mistakes in cleaning tableware, hoping to help you!
      錯(cuò)誤1:其實(shí)很多人在洗碗的時(shí)候犯的大錯(cuò)誤就是將所有的碗筷都堆積在一起清洗,一來是感覺這樣清洗方便,又能更快捷!其實(shí)這樣可能會(huì)引起碗筷的交叉污染,所以一般來說我們建議先清洗比較干凈的碗,然后在清洗油膩的碗,這樣其實(shí)是更加省力又干凈的。
      Error 1: In fact, the big mistake many people make when they wash dishes is to stack all the dishes and chopsticks together to clean them. First, it feels convenient and faster to clean them. In fact, this may cause cross-contamination of bowls and chopsticks, so generally speaking, we suggest cleaning cleaner bowls first and then greasy bowls, which is actually more labor-saving and clean.
      錯(cuò)誤2:浸泡時(shí)間過長也是很多人會(huì)犯的一樣錯(cuò)誤,很多人在使用了碗筷之后都會(huì)先將碗筷浸泡在水中方便等下清洗,但是這樣的做法是錯(cuò)的,因?yàn)橐话銇碚f長時(shí)間的浸泡碗筷容易讓碗上滋生并附著更多的污漬,所以浸泡的時(shí)間不應(yīng)該過長,應(yīng)該吃完飯就快速洗碗。
      Error 2: Soaking for too long is the same mistake many people will make. Many people will soak the bowls and chopsticks in water after using the bowls and chopsticks for easy cleaning, but this is wrong, because it is easy to grow and attach more stains to the bowls for a long time, so the soaking time is wrong. It shouldn't be too long. It should wash the dishes quickly after eating.
      錯(cuò)誤3:在清洗好碗筷之后,都會(huì)為了省事就用擦碗布將碗擦干收入碗柜中,抹布上也會(huì)有很多細(xì)菌,這樣又會(huì)把洗干凈的碗筷交叉污染,我們可以再碗筷洗好之后放在干燥通風(fēng)的地方直接讓碗晾干即可。
      Error 3: After cleaning the chopsticks, they will dry the dishes in the cupboard with the dishcloth to save time. There will also be a lot of bacteria on the dishcloth, which will cross-contaminate the clean dishes and chopsticks. We can dry the dishes directly in a dry and ventilated place after washing the chopsticks.
      今天的精彩內(nèi)容就暫且和大家介紹到這里了,如果大家有其他想要補(bǔ)充的地方,歡迎大家到一次性餐具廠家的官網(wǎng)給我們留言評(píng)論:http://m.hydronic.cn,或者直接撥打我們的咨詢熱線,我們將給您一個(gè)滿意的答復(fù)!
      Today's wonderful content will be introduced here for the time being. If you have other places to add, you are welcome to leave a message and comment on the official website of disposable tableware manufacturers: http://m.hydronic.cn, or call our hotline directly. We will give you a satisfactory answer!
